Schwalbe Marathons
Schwalbe Marathons
Postby Tim » Sat Mar 09, 2013 4:31 pm
Just been checking my tyres and was a bit surprised to find how poor a condition my rear tyre is in.
I'm still on the original Schwalbe Marathon that hasn't even done 3000km's yet.
There are at least 6 cuts in the tread that are about 3/4 of an inch long. Each cut sits on the edge of the knobby section of tyre and passes right into the green guard. The tread looks split more so than cut.
Admittedly I've been riding over some sharp rocky roads with a heavy load but I expected better than this.
The basic/original Marathon isn't an expensive tyre so it's not a major problem I just thought they were a bit tougher than they appear to be. Still, I haven't had to mend a puncture yet so the green guard seems to work.
Tim
by Forum Ads » Sun Mar 10, 2013 8:57 am
Re: Schwalbe Marathons
Postby Tim » Sun Mar 10, 2013 8:57 am
Thinking of trying out one or two of the Vittoria Randonneur tyres.
I know that tyre threads have been done to death but I can't find much info doing a quick forum search.
il Padrone has recommended Vittoria in the past, I think. There are several Vittoria Randonneur City/Touring models.
Wiggle have these; http://www.wiggle.com.au/vittoria-randonneur-touring-city-tyre-2012/ and others at fairly cheap prices.
IP, which model do you use?
Any other recommendations?
Is the Shwalbe Marathon Plus any superior to the original Marathon?
I ride mostly bitumen and good trails but occassional rough stuff that appears to have cut up the Marathon originals.
Tim
Postby RonK » Sun Mar 10, 2013 9:06 am
Unless you live in thorn country, or can't manage an occasional puncture repair, I 'd give the Plus a miss - they are extremely heavy.
For the kind of mixed surfaces you ride the Dureme might be a good choice, otherwise it's the heavy duty Mondial.
Postby Tim » Sun Mar 10, 2013 9:14 am
Thanks Ron.
Yoohoo, il Padrone. I know you're around here somewhere? :)
Tim
Postby il padrone » Sun Mar 10, 2013 9:55 am
The best Vittoria tyres that I have used are the Randonneur Cross. I have then in the 26x1.75 size and have routinely had ~14,000kms before any of the red puncture-protecting layer starts to show. They are also available in 700C, the narrowest being 28mm. There is also the standard Randonneur for a more slick tyre (I have had one puncture in these, but also very tough), and the Randonneur Pro for a folding tyre - I am about to fit these for our forthcoming tour of Italy.
I picked up a Marathon Cross trye once..... brother what a log!! The same size tyre as my Rando Cross weighs 50% more. But they're puncture-proof you say. Well I've yet to have a penetration puncture in my Randonneur Cross, and that's with travel through known thorn country and on one occasion pulling a number of thorns out of the tyre.
Postby Aushiker » Sun Mar 10, 2013 11:23 am
I have the Schwalbe Marathon Mondial HS428 47-622 28 x 1.75 on my Surly Long Haul Trucker at the moment and they have done 3,626 km. I fitted them for my Chasing the Dirt tour. They are wearing good, I find them good on the bitumen and on the dirt roads (within their limitations), but I have had two punctures with the tyre fitted to the trailer, not the bike. One was a grass seed through the side wall but not sure of the other cause.
They are not a light tyre but coming in at 760 grams.
Postby Tim » Sun Mar 10, 2013 12:21 pm
Thanks Andrew, Ron and Peter.
Once again some good, well informed advise.
Tim
Postby Becker_11 » Sun Mar 10, 2013 1:21 pm
I'm no expert but from your description it seems the tyre may have been under inflated and compressed against a rock or other hard edge causing the split. Have you checked the pressures you're using against the maximum recommendation on the sidewall?
Sent from my Samsung Galaxy S3 using Tapatalk 2
Regards
Nathaniel
A great adventure starts with a single step
Becker_11
Postby Tim » Sun Mar 10, 2013 2:00 pm
Becker_11 wrote:... seems the tyre may have been under inflated and compressed against a rock or other hard edge causing the split. Have you checked the pressures you're using against the maximum recommendation on the sidewall?
Thanks for the suggestion but if anything I thought the tyres may have been overinflated for rocky conditions. I normally run them at about 70 PSI as was the case when I suspect the damage was done.
Somehow I think this rock would have sliced up almost any tire. It was lightly scattered, 40-60mm diameter, crushed blue-metal, very sharp and pointed.
It looked like this;
The trouble arose whenever I unavoidably and frequently rode over a single piece of this rock on an already hard packed and dry clay substrate.
I've seen similar rock puncture a knobby 4WD tyre so the Marathons probably did ok not puncturing.
Tim
Postby Baldy » Sun Mar 10, 2013 2:37 pm
Gday Tim
I did about 6000km on a set of Vittoria Randonneur Cross Pro. Touring and general around town stuff and they were good, roll well and only 2-3 flats that I can remember and that was torwards the end and part of the reason I replaced them. They still have a tiny bit of tread showing in the centre and would probably do a few more thousand km without too much trouble. I kept them as spares.
I replaced them with Schwalbe Marathon Extreme. Having bigger nobbies they don't roll quite as quick but they have been very good.Done around 3000km and are wearing well, just to the point of swapping the rear to the front to even up the wear rate a little.[some people don't agree with doing this but what would they know eh!] Both sets are 32mm but the marathons are a bigger tyre.
Baldy
Postby Tim » Sun Mar 10, 2013 3:28 pm
Thanks Baldy.
I might give the Vittoria Randonneur Cross a try.
Cycling Express have them for $24.95. Cheap as.
Tim
Postby rifraf » Tue Mar 12, 2013 7:34 pm
I've absolutely no complaints about my Marathon Plus's and would happily buy them again for my Moulton.
I've had about four punctures from memory but I find them easy to get on and off my Aeroheat rims.
With the amount of glass that seems to abound in my area of WA I'm only surprised I havnt had more punctures.
I was initially worried about the weight handicap due to them being much heavier than my initial Maxxix tyres but they have proved their worth and I've
never really noticed the extra grams. :D
Good luck with the choice :D
Moulton Landrover APB
rifraf
Postby WestcoastPete » Tue Mar 12, 2013 8:22 pm
I'm pretty happy with my Marathon Supremes. They're much lighter than the standard Marathons. I had issues up in Darwin with splits in the sidewalls after being fitted for a year on the folding bikes (20" wheels). The same happened to the Supremes I fitted as replacements actually, but the Supremes on my expedition bike (26" wheels) are still all good. I have had two punctures with them, both on tour. One was a packing staple and the other was some sort of nail. I'm not convinced that the Marathons would have any better luck.
As an aside; I've never used the Vittoria Randos, but I plan to...
WestcoastPete
Postby rifraf » Tue Mar 12, 2013 8:26 pm
Tim wrote:Thanks Baldy.
Very hard to argue with that price especially with the good mileage that IP gets out of a set.
Give em a twirl and report back :D
rifraf
Postby Baldy » Wed Mar 13, 2013 12:13 pm
Just to be clear mine are the Cross Pro which are the folding version. Bit lighter but I have no idea if they have the same rubber. Tread pattern looks the same.
I very much doubt you will get 10k out of the rear on one of these. I forgot about another set of tyres I have, so revise the km down to about 4k on the cross pros.
Baldy
Postby il padrone » Wed Mar 13, 2013 12:26 pm
Hmm.... I was looking around for this folding version to replace the worn Vittoria Randonneur Cross, but couldn't find them in 26", only 700C. Have you got them in 700 or 26", Baldy? Ended up getting the somewhat slicker tread Randoneur Pro.
As to mileage, they seem to be the same casing as the Rando Cross, so should give the same life as the wire bead version. I have consistently had ~14,000kms. That's on all sorts of road surfaces and a lot of fully loaded touring. Maybe the 700c in a narrower width gives less life. :? :?:
Postby rifraf » Sat Mar 16, 2013 2:23 pm
il padrone wrote:Hmm.... I was looking around for this folding version to replace the worn Vittoria Randonneur Cross, but couldn't find them in 26", only 700C. Have you got them in 700 or 26", Baldy? Ended up getting the somewhat slicker tread Randoneur Pro.
I believe "consistent" correct tyre pressure range has a lot to do with longevity in tyres.
Regardless of whats offered on the casings by manufactures many riders think they know better. :shock: :roll:
rifraf
Postby Baldy » Sat Mar 16, 2013 7:16 pm
Yeah mine are 700c. They still have life in them and if I got another couple of thousand k's I'd be happy overall.
You might have been on it? Our main bike track here is about 15km long and has 14 road crossings. Gates on both sides of them all and some are tighter than others. So lots of braking and taking off again. Being the hoon that I am that means lots of late braking and out of saddle to get going again, half the time while still going through the gates. You can hear and feel the tyres begging for mercy :lol:
Baldy
Postby polishbiker » Sun Mar 17, 2013 3:17 pm
my last tour i used swhcalbe supreme 26x2.0, lasted 10.000km without swapping around, had 1 puncture but was internal, really good tires in my opinion.
waiting for 26x20 schwalbe mondial evolution to arrive for my next trip so will see how they go.
polishbiker
Return to Touring Bikes and Equipment
cron
