Front light
Mike Ayling
Front light
Postby Mike Ayling » Thu Jun 27, 2013 4:22 pm
While not planning to tour in the dark I seek suggestions for a medium power (maybe 100-150 lumens ) front light but must run on AA or AAA cells.
USB is not for me because I do not drag a laptop or similar device around with me.
Mike
}SkOrPn--7
Re: Front light
Postby }SkOrPn--7 » Thu Jun 27, 2013 7:58 pm
Hi Mike for my everyday run of the mill front light I use one of these it has about 5 setting from 3 brightness and I think 2 strobe but don't hold me too that because I will have to check. It gives a good spread of about 3-4 wide and lights up to about 15 meters in front of you. Runs of AAA which I like because so does my rear lights. It comes with all the parts to mount on bike or helmet and for $24 USD it's bang for buck in my opinion. I can't remember but I think mine came with a head band as well. Just so you know I'm a long distance tourer so I want things to be reliable and it's no bigger than 2 match boxes stacked on each other. I use the slow strobe setting and no issues getting 3 months use from a set of batteries maybe longer. One other point it's waterproof.....
http://princetontec.com/eos-bike
Ricky
ShogunHy
Re: Front light
Postby ShogunHy » Thu Jun 27, 2013 10:20 pm
Planet Bike Blaze - I got a 1W but the newer 2W is out and is good value for money mid range..
Shogun Metro SE Flat Bar Hybrid - Circa late 90's
Specialized Sirrus Comp - 2011
Cheesewheel
Re: Front light
Postby Cheesewheel » Thu Jun 27, 2013 11:35 pm
Mike Ayling wrote:While not planning to tour in the dark I seek suggestions for a medium power (maybe 100-150 lumens ) front light but must run on AA or AAA cells.
Mike
I opted for a headlamp, since it is more versatile than a bike light and easy enough to mount on the helmet if I ever get caught out when the sun goes down.
I got the spark AAA from thee guys, although there are a range of other products that you might find more suitable
http://www.eliteoutdoorgear.com.au/cate ... lamps.html
Go!Run!GAH!
Re: Front light
Postby il padrone » Sat Jun 29, 2013 7:35 am
I know it's not in your spec Mike, but I have to say it: dy - na - mo.
I run mine whenever the bike is ridden, day and night. I have found very real advantages in the daytime use of the headlight.
Mike Ayling
Re: Front light
Postby Mike Ayling » Sat Jun 29, 2013 8:51 am
Thanks for all your replies.
Mike
Mike Ayling
Re: Front light
Postby Mike Ayling » Sat Jun 29, 2013 8:53 am
il padrone wrote:I know it's not in your spec Mike, but I have to say it: dy - na - mo.
Good point about day time running Pete.
I have been running my motor vehicle headlights during the day for about ten years now.
Mike
Users browsing this forum: bicyclewarrior
