Cycle shoes for touring?
Re: Cycle shoes for touring?
Postby TheShadow » Fri Jan 01, 2016 11:18 am
As you allude to, I could spend a lot of time running around to various lbs around the city and struggle to find many of the models I'm interested in, in my size. And even if they did, I'm not sure that the cycling shoe industry has not simply taken a calculated decision that cyclists with my size/shape of foot are not a market segment big enough to be worth catering to. Possibly it is now more than ever a good idea for wide-feet cyclists to go custom.
I have enquired about that a few years ago. I forget the exact price but it was a lot. Mind you, compared to a few pairs of shoes that you buy and then just can't use, half a dozen trips to physios and Podiatrists, pain and suffering - damage - and that's not a cheap option either!
I do take your point about walking, also. But I'm probably not going to be fording creeks in the next 6 months, like you are. I'm not real keen to get into the mud and bull dust, either. Does that make me more of a 'Soft-Roader' than an 'Off-Roader'? In the short term, I don't think I'll be doing much pushing in metropolitan areas. With granny gears, a modest load, and sticking to hard surfaces, I think I still have enough strength and bloody-mindedness to not get off and push. But I could be wrong. It's happened once before.
Postby Uncle Just » Fri Jan 01, 2016 11:23 am
- Tim
Postby Tim » Fri Jan 01, 2016 11:36 am
I've been wearing a now discontinued model of LG lace-up Strada shoes for touring for several years.
Well made, real leather upper in parts, recessed cleats and good rubber grip for pushing a heavy load up either bitumen or dirt steep hills.
Next time I'll be looking at something like these;
http://www.louisgarneau.com/ca-en/produ ... LING_SHOES
- Leaf T
Postby Leaf T » Fri Jan 01, 2016 12:38 pm
- RonK
Postby RonK » Fri Jan 01, 2016 12:58 pm
- queequeg
Postby queequeg » Fri Jan 01, 2016 1:08 pm
I find them quite comfortable, and as with others have gone up a size from normal.
I've also got a pair of MT-42 Shoes which I really don't wear very much anymore. I have RT-31's as a backup to my RT-82, and I also have some Specialized Rime Shoes with a Vibram sole. They are a Mountain bike shoe though.
I've thought about trying the Specialized Audax shoes, but have not had a chance to hunt down a shop that stocks them.
- cyclotaur
Postby cyclotaur » Fri Jan 01, 2016 1:19 pm
Ditto - RT82s used for everything inc touring.queequeg wrote:I use the Shimano RT-82 shoes for commuting, and road riding on my steel steed.
My old blog - A bit of fun
Postby TheShadow » Fri Jan 01, 2016 3:03 pm
I do have one question though. I'm not trying to put the RT82 down. Does the RT82 do anything an M089 (mtb shoe) doesn't do? Both pretty rigid, 3 straps. Both have limited walking capability on pavement.
If you want shoes you can really walk in, I think you're going to have to accept some compromises. It's hard to let go of wanting a 100% rigid sole and 3 straps. I'm leaning towards one of the Vibram Shimano shoes. It's really not much dearer than an RT82. Actually, atm they're the same price as RT82 PLUS a pair of Adidas slides. I'm trying not to think of that. (Thinks: Must. Be. Practical.)
I think it's only a small risk the MTs won't be almost the same as my R087 Wide, given it is almost too big for me. It's a 48...if you're having serious width issues, you gotta be prepared to go the 'clown-shoe' route with Shimano. I've discovered I can live with that. That was my reasoning for buying the cheaper 'ridiculously-large-by-my standards' R087 in the first place...it was an experiment.
I looked at the LG. Not much cheaper. Not a bad sole, but not beefy MT Vibram standard either. Yes, the sizing looks better: I think I could get the same width in a 6mm shorter shoe, maybe more if I could actually get say a half size 46.5...but I am past caring about that so much anymore. I've lived with the R087 long enough to get used to it.
- queequeg
Postby queequeg » Fri Jan 01, 2016 3:27 pm
They are lighter than a mountain bike shoe and have a fairly rigid sole. My RT-31 Shoes are flimsy in comparison, if that at all helps.
Postby TheShadow » Fri Jan 01, 2016 3:46 pm
So you would happily wander around a suburban shopping complex for 30 min without risk of slipping or falling? They can take that once or twice a week without rapidly wearing out the soles? Basically they can walk anywhere on pavement? Only real limitation is traction if you get off a hard surface?
EDIT: I just blew up the image of them onto full screen and spun them around a few times. The heel is just those two little pieces of rubber. I don't know if they're replaceable or not. But that's a lot less than even say a M089 mtb shoe has on the heel, and I'd figured THEY must wear out fast. An MT71 is probably a way more substantial sole than I need right now, but at the complete other extreme I'm wary of those very tiny heel supports on mtb or MT82. The LG Escape is somewhat of a middle ground by comparison...a less full-on MT71, for a THIRD the money at RRP.
- cyclotaur
Postby cyclotaur » Fri Jan 01, 2016 4:08 pm
RT82s are fine to wear all day and go shopping in etc but at night you want to give your feet a rest.
Postby TheShadow » Fri Jan 01, 2016 4:22 pm
- cyclotaur
Postby cyclotaur » Fri Jan 01, 2016 4:54 pm
I'm pretty easy on gear though....
- kb
Postby kb » Sat Jan 02, 2016 6:59 am
http://www.lookcycle.com/en/uk/route/pe ... uring.html" onclick="window.open(this.href);return false;
- RonK
Postby RonK » Sat Jan 02, 2016 10:14 am
Postby TheShadow » Sat Jan 02, 2016 4:01 pm
I'm not trying to put you on the spot or anything, but I just rang Avanti Cycles at Croydon, Vic regarding LG Escape...all sounded positive until I asked about sizing. He said they did not sell Shimano and couldn't offer any comparison to their sizing, but after going and speaking with the manager he said LG are NARROWER than even Shimano. Can that be right? Is that even physically possible?Tim wrote:Louis Garneau shoes seem to be a wider fit than Shimano. I have a broad foot too.
It's quite possible their sizing has even changed sometime recently. I did some Googling on Carnac shoes, because they USED to be wide...apparently that is no longer the case since about 2006, if what I read is to be believed. I think it was some forum connected to Colorado Cyclist. Not that that's terribly relevant since you just about can't find any Carnac shoes anymore.
- Tim
Postby Tim » Sat Jan 02, 2016 5:34 pm
That LG shoes are even narrower than Shimano shoes sounds like an off the cuff, probably ill or uninformed opinion.
Who knows? Best thing is to try a pair on.
I suspect shoe widths vary from model to model and differ between road and mountain bike/touring models, within a single manufacturers range.
Postby TheShadow » Mon Jan 04, 2016 6:26 am
http://www.shimano-lifestylegear.com/gl ... _lasts.php" onclick="window.open(this.href);return false;
Postby TheShadow » Wed Jan 06, 2016 6:01 am
Their reply:
Thanks for your email,
This is correct. We believe in a closer feel in order to have greater control and power transfer.
As always however, we recommend that you return to your local Louis Garneau dealer to try a pair. Please inquire with our distributor in Australia, Monza Imports, http://www.monzaimports.com.au" onclick="window.open(this.href);return false; for further information on our products and retail locations.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
Users browsing this forum: Google Feedfetcher
- All times are UTC+11:00
