Stability - Handlebar vs rack mounted front bags
Postby Espresso_ » Wed Apr 22, 2015 9:56 pm
I'm trying to decide between getting a handlebar mounted front bag (klickfix etc) or buying a front mini rack and rando-style bag. EDIT: or a backpacking style soft bag.
There may be a number of differences between the options but I'm interested in views on the relative stability of these options (ie the bag and contents moving around over bumps etc).
Any guidance?
E
Re: Stability - Handlebar vs rack mounted front bags
Postby Uncle Just » Wed Apr 22, 2015 10:19 pm
I'd recommend a barbag but you may be able to carry more with a rack/bag setup if that's your need.
Postby BenGr » Thu Apr 23, 2015 11:21 am
Postby Espresso_ » Thu Apr 23, 2015 1:29 pm
Do you mean that it pulls the steering to one side when stopped etc?BenGr wrote:The only stability problem i've had with a bar bag (Arkel Large) was while stationary.
E
Postby Blakeylonger » Thu Apr 23, 2015 3:00 pm
soft bikepacking style bags offer limited benefits for rigid drop bar type bikes. but a top of TT bento and bar/stem feedbag is totally worth it for snacks, cameras, beers...
I can easily put 6-10kg in my barbag with no issues, but it's on a one piece cr-mo rack.
Postby BenGr » Thu Apr 23, 2015 3:15 pm
Pretty much. Its only an annoyance really. Dropped my bike a few times as the front wheel could turn very easily if it wasn't balanced/leaning against something properly. You'll likely have this problem with any setup with the weight fairly high.Espresso_ wrote:Do you mean that it pulls the steering to one side when stopped etc?BenGr wrote:The only stability problem i've had with a bar bag (Arkel Large) was while stationary.
E
Postby Espresso_ » Thu Apr 23, 2015 4:40 pm
Why? Too small or some other practical issue? I get that they interfere with the brifters.Blakeylonger wrote: soft bikepacking style bags offer limited benefits for rigid drop bar type bikes.
E
- singlespeedscott
Postby singlespeedscott » Thu Apr 23, 2015 5:01 pm
Do search on handling and bags on this blog - https://janheine.wordpress.com" onclick="window.open(this.href);return false;
Postby b3n » Thu Apr 23, 2015 5:35 pm
I used a 30 degree stem, inverted, with a few inches of sawn-off handlebar to mount my ortlieb bag down low. It works really well, lowering the bag improves handling and visibility (good if you're riding rough tracks etc):
- RonK
Postby RonK » Thu Apr 23, 2015 5:36 pm
Handlebar bags tend to make the steering flop because the bags may anything up to 200mm ahead of the steering axis. A bag on a randonneur rack would be a little closer.BenGr wrote:Pretty much. Its only an annoyance really. Dropped my bike a few times as the front wheel could turn very easily if it wasn't balanced/leaning against something properly. You'll likely have this problem with any setup with the weight fairly high.Espresso_ wrote:Do you mean that it pulls the steering to one side when stopped etc?BenGr wrote:The only stability problem i've had with a bar bag (Arkel Large) was while stationary.
E
In any case it's easily fixed with a steering stabiliser such as this Velo-Orange version.
Or this Hebie Steering Damper
- RonK
Postby RonK » Thu Apr 23, 2015 5:39 pm
A tidier option is a Thorn Accessory Bar.b3n wrote:If you have sufficient steerer below the stem, you could try something like this:
- il padrone
Postby il padrone » Thu Apr 23, 2015 6:39 pm
Postby Espresso_ » Thu Apr 23, 2015 10:31 pm
https://www.revelatedesigns.com/blog/in ... -drop-bars
It's close to the bars (and attached to the headtube?). Less accessible on the go alone, but the Pocket attachment could provide that access and I already have the Tangle frame bag which provides quick access too.
Bonus is that it can move to my flat bar bike without needing a rack or klickfix attachment.
E
- RonK
Postby RonK » Thu Apr 23, 2015 10:58 pm
Well, that's not a handlebar bag, that's a drybag. You'll need a Pocket to go with it and probably a Gastank and Jerrycan as well.Espresso_ wrote:I wonder if anyone can speak to the stability of a setup like this?
That's the way I'll be going for my Fargo build, although I'm undecided yet whether to go for a sweetroll or a harness and drybag.
Postby b3n » Thu Apr 23, 2015 11:45 pm
[/quote]
I didn't have one of those. What I did have was a hacksaw [emoji1]
Postby Espresso_ » Sun Apr 26, 2015 9:11 pm
Now to look into seat bags, like a Cococino, Viscacha etc ...
PS why are these not called "seatpost" or "saddle" bags?
- RonK
Postby RonK » Sun Apr 26, 2015 9:19 pm
They were named by Americans.Espresso_ wrote:PS why are these not called "seatpost" or "saddle" bags?
