Croozer bike trailer stroller wheel not turning
digbyj
Postby digbyj » Wed Jan 25, 2017 9:21 am
Hi,
As above, when you install the stroller wheel on my Croozer it goes in as normal and moves around freely, however when you actually push the stroller the wheel doesn't turn and just drags.
Anyone experienced this?
MattyK
Re: Croozer bike trailer stroller wheel not turning
Postby MattyK » Wed Jan 25, 2017 12:54 pm
Yep, mine started the same thing after a while of ownership. Not completely binding up, but wouldn't align as well as it originally did.
Never solved it properly; sold the trailer once the kids outgrew it. A bit of grease helped, but makes things messier... I guess the ultimate solution would be to ream out the hole and put a proper sleeve bearing in there.
digbyj
Postby digbyj » Wed Jan 25, 2017 10:02 pm
I've put some grease and is working at the moment. We will see...
Cheers!
