Page 1 of 1
Oppy C5 cable routing
Posted: Sat Aug 24, 2013 3:13 pm
by CAAK
Build under construction.
C5 2011ish model. Can you educate me on best way to route front derailleur cable?
Photo would be helpful.
Also do you run gear cable outter all the way through frame?
If not are special large ferrals required at the holes into head tube?
Thanks.
Re: Oppy C5 cable routing
Posted: Wed Aug 28, 2013 8:41 pm
by familyguy
Inners run all the way through, from shifter to below the BB junction. Put a ferrule on the BB end.
Posted: Mon Sep 02, 2013 10:13 am
by ACT SC600
CAAK wrote:Build under construction.
Thanks.
Andrew.. I have 2 oppy C5s - plus I'm located in the ACT... Let me know if you want to have a look
Cheers chris
