(perth) 700 Wheelset + Shimano 600 Crank Arm + Mondolo Brake
Newbies, please read the Market Place Rules before posting in this section.
POST FORMAT: [LOCATION] description (WTB not required)
mxmort
Postby mxmort » Thu Apr 25, 2013 6:39 pm
I am after a non drive crank shimano 600 170mm (same as the model as the drive side in picture)
Have shimano 600 172.5mm or shimano 600 165mm to swap or will buy outright
Also after the proper cable adjuster for these mondolo brakes
It looks like it should be like the normal ones but with a flat piece cut out so it doesnt spin (hope this makes sense)
Lastly im after a set of 700 wheels or even just 700 rims to suit late 80s model
I really dont know much about geared bikes as i am a bmx person so i dont know what dish etc (sorry but all new to me )
At the moment i have a set with 7 gears but have been told the dish is out and i cant replace the freewheel as its the old bolt on type (hope this makes sense)
If someone can help me out in perth with their knowledge or a set of wheels that would be awesome
Sorry for all the confusion but this is all new to me
I have a picture of the bike i am trying to build in the retro build section under alloy bike id
Thanks heaps
zues
Re: (perth) 700 Wheelset + Shimano 600 Crank Arm + Mondolo B
Postby zues » Fri Apr 26, 2013 10:05 pm
Hi mxmort,
I have a 170mm Shimano left crank 6207. Good condition though the black print is faded on the shimano part of shimano 600.
I am after a 165mm left crank for a shimano arabesque. Is yours a 165mm?
Regards
Henry
mxmort
Postby mxmort » Fri Apr 26, 2013 11:24 pm
Hey Henry
Mate the arabesque is 165mm
I dont know the numbers for shimano but i am after the non drive for the one in the centre of picture as long as threads are good
cheers chris
Postby Dan » Sat Apr 27, 2013 10:50 am
A swap made in heaven. Chris, the model number is stamped on the inside of the crank arm. Its 6207.
mxmort
Postby mxmort » Sat Apr 27, 2013 11:37 am
Thanks Dan
Thats the one i am after
zues
Postby zues » Sat Apr 27, 2013 4:57 pm
Chris,
message sent.
Henry
mxmort
Postby mxmort » Mon Apr 29, 2013 1:35 pm
Crank arm sorted
Still after wheels
mxmort
Postby mxmort » Sat May 04, 2013 11:47 am
All sorted thank you
Users browsing this forum: Calvin27
