[BNE] Campy freehub body
Newbies, please read the Market Place Rules before posting in this section.
POST FORMAT: [LOCATION] description (WTB not required)
retrograded
Postby retrograded » Wed Jul 17, 2013 1:15 pm
I'm looking for a freehub body for a 2001 Chorus hub, I understand that either a Record (FH-RE415), Chorus (FH-CH215), or Daytona (FH-DA015) will do the job.
These parts are no longer made, and have been out of production since 2007 from what I can understand, so I hold out a slim hope of finding one. Any assistance that you could provide would be appreciated.
Velo13
Re: [BNE] Campy freehub body
Postby Velo13 » Thu Jul 18, 2013 7:47 pm
Hey Glenn, have you tried Felice Santoro at Cycling Projects in Sydney. He has heaps of that type of stuff.
But what's the problem? Is it bearings? They are replaceable, I have done it a couple of times, but it's a bit of a job. Try to find a new one first.
Here's a thread of mine from waaaay back with some details. There's a lot more posts out there since then. Googlize it.
retrograded
Postby retrograded » Thu Jul 18, 2013 8:43 pm
Hi Josh, thanks for the tip about Cycling Projects, I'll give them a call in the morning.
I wish it was as simple as servicing/replacing the freehub bearings, the freehub body has a 2cm crack along the base of one of the freehub splines running from the hub flange outward, it made removing the cassette quite difficult. My friend Google tells me that this was not an uncommon occurrence, and may have even been the reason that Campy changed the freehub design from 2007 on.
Once again, thanks for the tip.
Velo13
Postby Velo13 » Mon Jul 22, 2013 7:07 pm
Whoa, not seen that. Good luck with that.
