510 Workouts
Rex
510 Workouts
Postby Rex » Fri Jun 27, 2014 4:48 pm
With the Edge 510 is it possible to load and start a new workout while moving?
Also, am I able to set tones on for certain functionality but off for others?
ie. I prefer to have my Garmin silent, except when performing a workout. Is this possible?
DuncanS
Re: 510 Workouts
Postby DuncanS » Sat Jun 28, 2014 3:32 pm
First question: yes but you need to hit "ride" before starting the ride recorder with the "play" button. If you just hit the "play" button, you can't start the workout. That had me stuffed a few times.
Second question, I don't believe so but haven't tried to did a way. I've silenced mine.
Side note - I find it utterly useless for short intervals like Tabata. There is unpredictable latency where the 510 is thinking about something else rather than alerting for the interval.
Rex
Re: 510 Workouts
Postby Rex » Sun Jun 29, 2014 9:13 pm
OK cheers, I'll try that out.
Interesting about the latency, but I still may try them as it's definitely safer than glancing at the Garmin more often than I should at speed + exhausted.
DuncanS
Re: 510 Workouts
Postby DuncanS » Sun Jun 29, 2014 9:21 pm
Good luck. I'm sure the interval timers will be fine for longer intervals.
