Garmin 810 Issue
Bluejay87
Garmin 810 Issue
Postby Bluejay87 » Tue Dec 09, 2014 9:36 am
Just got a new 810 and I have one issue where on the exact same spot on my commute the unit just turns off. Never happened in any other location.
I couldn't understand losing GPS connection in the exact same spot but I don't understand how the location could turn the entire unit off.
Anyone experienced similar?
leximack
Re: Garmin 810 Issue
Postby leximack » Tue Dec 09, 2014 10:31 pm
Bluejay87 wrote:Just got a new 810 and I have one issue where on the exact same spot on my commute the unit just turns off. Never happened in any other location.
Aliens or Ninja's. :shock: :shock: :lol: :lol: :lol:
3DKiwi
Postby 3DKiwi » Wed Dec 10, 2014 6:20 am
Are you running the latest firmware?
If yes then I suggest posting the question in the Garmin 810 forums: https://forums.garmin.com/forumdisplay.php?362-Edge-810
Bluejay87
Postby Bluejay87 » Wed Dec 10, 2014 8:02 am
Its a new 810 but not sure if it came with the latest firmware or not. I'll have to check. Thanks.
Bluejay87
Postby Bluejay87 » Mon Jan 05, 2015 9:12 am
Finally got around to upgrading the firmware but the issue still happens. It's so strange that it only turns off at this one location, but it happens every single time, and never anywhere else.
I'll post in the Garmin Forums.
Hugor
Postby Hugor » Mon Jan 05, 2015 9:33 am
Spooky!! Cant be a location thing, must be time related. Tried commuting a different route? What happens on the return journey?
Bluejay87
Postby Bluejay87 » Mon Jan 05, 2015 9:50 am
Yes there is minor detour I can take which prevents it turning off. On the way home, it has only turned off in that spot once. It is definitely location related. It is quite annoying as I have to stop to get a GPS fix otherwise it won't lock on again for a km or 2.
