Garmin + DuoTrap
flashpixx
Garmin + DuoTrap
Postby flashpixx » Tue Jan 13, 2015 12:06 pm
For those that have a DuoTrap and Garmin set up (eg 500/510 etc), do you use the speed sensor in the DuoTrap or in the Garmin?
If using the Garmin then DuoTrap only provides cadence?
Flash
Riding: Pinarello Dogma2
Re: Garmin + DuoTrap
Postby jasonc » Tue Jan 13, 2015 12:38 pm
does both speed and candence:
http://www.bontrager.com/model/08298
Carrots
Postby Carrots » Tue Jan 13, 2015 12:40 pm
No different to using the older style Garmin Speed/Cadence sensor, or the Giant RideSense. Chuck a magnet on the wheel and use the DuoTrap. If you use the Garmin only it'll be determining your speed based on GPS/satelite movement and can be a bit iffy at times.
Go with the Duotrap :)
flashpixx
Postby flashpixx » Tue Jan 13, 2015 2:38 pm
Carrots wrote:No different to using the older style Garmin Speed/Cadence sensor, or the Giant RideSense. Chuck a magnet on the wheel and use the DuoTrap. If you use the Garmin only it'll be determining your speed based on GPS/satelite movement and can be a bit iffy at times.
cheers :D
Flash
bitstuffer
Postby bitstuffer » Mon Dec 14, 2015 7:11 pm
A question: I fitted a duotrap today to run with my 510, all good though I am wondering about the speed thing, shouldn't there be some way to give the circumference to the computer for the times it calculates speed sans satellite positioning? I had the Garmin speed / cadence sensor on prior, this question relates to any sensory gear, just find it strange coming from a Cateye past where we entered the circumference for the speed and distance to be accurate.
BS
Postby jasonc » Mon Dec 14, 2015 8:47 pm
Bitstuffer - in bike profile set the wheel size to manual
tapatalk for Windows Phone. For when you want it done right
bitstuffer
Postby bitstuffer » Tue Dec 15, 2015 10:16 am
jasonc wrote:Bitstuffer - in bike profile set the wheel size to manual
Ahh, too easy. Thanks Jason!
