Jockey wheels - need some
- mikesbytes
Postby mikesbytes » Sun Mar 08, 2009 10:28 am
I need 2 sets, both for Tigra derailers.
Postby }SkOrPn--7 » Sun Mar 08, 2009 1:01 pm
http://www.bbbparts.com/pulleys.php
I purchased mine from
http://www.deanwoods.com.au/store/category410_1.htm
- mikesbytes
Postby mikesbytes » Sun Mar 08, 2009 1:50 pm
$20 ain't bad at all.}SkOrPn--7 wrote:Not sure if these fit that derailleur but for my last two sets I have purchased I have used them. I find that there cheaper than Shimano and last longer not too mention you get fully sealed ball bearings in both lower/upper pulleys.
What's the difference between 10 and 11 ?
- jasimon
- Kalgrm
- il padrone
Postby il padrone » Sun Mar 08, 2009 3:21 pm
- mikesbytes
Postby mikesbytes » Sun Mar 08, 2009 4:08 pm
Postby heavymetal » Sun Mar 08, 2009 6:09 pm
The good thing about the BBB ones is that they come in colours.
Kev.
- Mulger bill
Postby Mulger bill » Sun Mar 08, 2009 8:12 pm
You won't regret it Mike, but forget the colours, they all look the same after 1000kmsmikesbytes wrote:Thanks Guys, I'll order 2 sets of the 11's
Shaun
- mikesbytes
Postby mikesbytes » Sun Mar 08, 2009 9:00 pm
- munga
Postby heavymetal » Sun Mar 08, 2009 9:20 pm
When I brought mine they came with a bag loaded with all sorts of spacers for different derailleurs.mikesbytes wrote:Just one passing thought, will I have a size problem with using 11 on my Tigra derailiers?
Kev.
- sogood
Postby sogood » Sun Mar 08, 2009 9:27 pm
Why would you need spacers? B/n the RD arms?heavymetal wrote:When I brought mine they came with a bag loaded with all sorts of spacers for different derailleurs.
- mikesbytes
Postby mikesbytes » Sun Mar 08, 2009 9:35 pm
Good point, I wasn't thinking of width.heavymetal wrote:When I brought mine they came with a bag loaded with all sorts of spacers for different derailleurs.mikesbytes wrote:Just one passing thought, will I have a size problem with using 11 on my Tigra derailiers?
Kev.
What about if the teeth of the jockey or chain might hit due to the larger diameter ?
Postby heavymetal » Sun Mar 08, 2009 9:39 pm
I wondered the same myself and pulled out a few other RD from my collection. On some, the joining bolts have a wider part than the thread, resulting in a wobbly jockey wheel as the cage can't be closed to the width of the wheels.sogood wrote:Why would you need spacers? B/n the RD arms?
A washer would probably do the same job, but the jockey wheels I brought came with little spacers instead. Luckily I didn't need them on my RD.
Kev.
Postby heavymetal » Sun Mar 08, 2009 9:43 pm
I'm not an expert, but I thought the diameters were the same, only more teeth.mikesbytes wrote:What about if the teeth of the jockey or chain might hit due to the larger diameter ?
I inadvertently changed mine from 10T to 11T and haven't had any problems, but the RD was a 9 speed to begin with, but fitted with 10T by the company when the bike was built to accommodate the 8 speed rear cluster.
Kev.
- Kalgrm
Postby Kalgrm » Sun Mar 08, 2009 10:37 pm
I'm not sure how that's possible. It implies the teeth would have a tighter spacing, meaning they would no longer mesh with the spacing on the chain links.heavymetal wrote:I'm not an expert, but I thought the diameters were the same, only more teeth.
Graeme
Postby heavymetal » Sun Mar 08, 2009 10:47 pm
You're right, hence I said I'm no expert. I don't have the old ones to compare with as one exploded into a million bits and the other got thrown in a rage of disgust after I discovered they were made out of compressed horse manure and had no bearings.Kalgrm wrote:I'm not sure how that's possible. It implies the teeth would have a tighter spacing, meaning they would no longer mesh with the spacing on the chain links.heavymetal wrote:I'm not an expert, but I thought the diameters were the same, only more teeth.
There's probably not much of difference in diameter, and if there is, don't tell mike anyway Let him find out and tell us the answer
Kev.
- sogood
Postby sogood » Sun Mar 08, 2009 11:07 pm
Postby Nobody » Mon Mar 09, 2009 5:42 am
Good to see Shimano is recycling.heavymetal wrote:You're right, hence I said I'm no expert. I don't have the old ones to compare with as one exploded into a million bits and the other got thrown in a rage of disgust after I discovered they were made out of compressed horse manure and had no bearings.
Postby Nobody » Mon Mar 09, 2009 5:48 am
I see these on cheaper bikes. I think one of the bikes in my family has one. Might take a look. I think they do this to run even cheaper (or no) bushes. The weight weenies wouldn't like them either as they look heavy regardless of what they weigh.sogood wrote:I have seen some huge after market jockey wheels fitted on standard road RDs. Supposedly they reduce transmission friction but sounded like good gimmics to me.
- sogood
Postby sogood » Mon Mar 09, 2009 10:24 am
The one in the photo is made of CF and is fitted to a DA RD. It ain't cheap that's for sure.Nobody wrote:I see these on cheaper bikes. I think one of the bikes in my family has one. Might take a look. I think they do this to run even cheaper (or no) bushes. The weight weenies wouldn't like them either as they look heavy regardless of what they weigh.
- mikesbytes
Postby mikesbytes » Mon Mar 09, 2009 2:19 pm
- sogood
Postby sogood » Mon Mar 09, 2009 8:47 pm
Cross chaining, extra bearings, poor derailleur trim etc. However, the gears makes the bike more rideable on climbs and descents, more than make up that 1% deficiency. A better tuck would also give you more than 1%.mikesbytes wrote:I've heard that a fixie has a 99% efficient chain drive where a derailier style geard bike is 98%. So what happens to the 1% ?
