Hi WebHead, welcome to the forum.
The majority of wind is actually against the torso, if you are looking for better aerodynamics, you are better off to get your body lower, so it has less frontal. This is the main reason that racers and tri bikes are quicker than flat bar road bikes. Tri bikes give slightly better aerodynamics off the body than traditional racers and sacrifice a bit of manuverabilty to gain this bit of aerodynamics over the racer.
What the aero bars do is bring the arms in alignment with the body, effectively reducing the amount of wind drag by something approaching the wind that would of hit your arms.
So my first recommendation would be to see if you can lower your handle bars, so to reduce the wind drag on the torso.
Burn plenty of
Glycogen
Frame Size Calculator
training log
