n ew bke pump
n ew bke pump
Postby lgbran » Tue Aug 25, 2009 4:51 pm
- jacks1071
Re: n ew bke pump
Postby jacks1071 » Tue Aug 25, 2009 6:17 pm
If you want one that'll last another 10 years, buy another Silca one. Most of the fancy modern day ones are rubbish. You can also get parts for the Silca ones so there is a chance that a dealer could repair it for you.lgbran wrote:silca floor pump has died after 10 years of use.. somethings gone in the base.. good pump but want something else any suggestions?
Re: n ew bke pump
Postby petal665 » Tue Aug 25, 2009 10:12 pm
Last month I bough the top of the line Lezyne CNC Floor Pump. I must say, it is actually feels like it is built better than the Silca. I'm hoping it works just as well.
Re: n ew bke pump
Postby badge » Tue Aug 25, 2009 11:03 pm
- grosry
Re: n ew bke pump
Postby grosry » Wed Aug 26, 2009 8:14 am
i have just got a cheap one from goldcross and when that breaks in years to come i will buy another cheap one!
Re: new bke pump
Postby lgbran » Wed Aug 26, 2009 9:15 am
- Aushiker
- CoffsGal
Re: n ew bke pump
Postby CoffsGal » Thu Aug 27, 2009 12:04 pm
Re: n ew bke pump
Postby backofthebunch » Mon Nov 09, 2009 12:07 pm
my tyres are asking for 125psi and what iv got now is a !! BAN ME NOW FOR SWEARING !! old broken foot pump so i' having no luch.
so any recomendations of good value for money, styles and brands of pump will be appreciated.
- sogood
Re: n ew bke pump
Postby sogood » Mon Nov 09, 2009 12:17 pm
Your tyres aren't asking for 125psi.backofthebunch wrote:my tyres are asking for 125psi.
Re: n ew bke pump
Postby backofthebunch » Mon Nov 09, 2009 2:35 pm
anyone wanna help a brother out?
- Jean
Re: n ew bke pump
Postby Jean » Mon Nov 09, 2009 3:28 pm
The more expensive ones in the shop (still Bontranger) had alloy barrels and various tweaks, but I don't see the point of an alloy barrel over a steel one in a track pump. What's it gonna do? Make you climb faster?
- m@
Re: n ew bke pump
Postby m@ » Mon Nov 09, 2009 3:34 pm
Similar story here - mine's an alloy Tioga brand from memory, about 45-50 bucks at LBS. Can't say I've ever taken it past about 115psi, but don't see why it wouldn't be capable of going to 125.Jean wrote:I paid about $45-$50 for a Bontranger floor pump a few years back (in an LBS, not online) and it's still going strong. It has a 'universal head' so I use it on my roadie, MTB and scooter (motorbike type, not foot powered). I tried it on the car once and it did the job, but too much work involved.
If I was buying now - would probably go Silca.
Re: n ew bke pump
Postby backofthebunch » Mon Nov 09, 2009 4:27 pm
I used to ride a bit of BMX and MTB so not sure what is the best on the rd.
at least I know about $50 should get something decent.
- CoffsGal
Re: n ew bke pump
Postby CoffsGal » Mon Nov 09, 2009 4:40 pm
For road bike use, make sure you purchase a floor pump with a narrow barrel. They pump less air on each stroke but allow a higher pressure. Some floor pumps have a wider barrel and they are much harder to use, and I think are more suited to MTB. I have seen a neat Cannondale one that has a switch that allows either lower pressure high volume or high pressure low volume....works very well.backofthebunch wrote:How much do you think i have to spend to get a decent pump?
The ones that I have seen that seem to be quality are around $100. Have seen plenty around $50 but wasn't impressed.
I run tubeless tyres and inflate to 100psi...110psi should be ok for most folk in day to day use...racing might warrant a higher pressure.
Emma
Re: n ew bke pump
Postby petal665 » Mon Nov 09, 2009 5:35 pm
- il padrone
Re: n ew bke pump
Postby il padrone » Mon Nov 09, 2009 7:34 pm
Go by whatever pressure the tyre manufacturer recommends on the sidewall to start with, and then:backofthebunch wrote:thanks guys, i wanna pump rd tyres, so probably wont even go to 125. Is that advisable riding on the rd to avoid puncturs??
http://sheldonbrown.com/tires.html#pressure
Sheldon Brown wrote:Savvy cyclists experiment with different pressures, and often even vary the pressure for different surface conditions.
Optimal pressure for any given tire will depend on the load it is being asked to support. Thus, a heavier rider needs a higher pressure than a lighter rider, for identical tires.
Since most bicycles have substantially more weight on the rear wheel than on the front, the rear tire should almost always be inflated to a higher pressure than the front, typically by about 10%.
Rough surfaces generally call for a reduction in pressure to improve ride comfort and traction, but there is a risk of pinch flats if you go too far.
Re: n ew bke pump
Postby Fletcher » Tue Nov 10, 2009 2:31 pm
When I bought my bike the lbs bloke told me unless I spent at least $60 on a pump it would be useless and I would hate the thing, and tried to convince me to pay $180 on some steel thing from Italy.
Azzitappenz, I like my dodgy Repco $20 floor pump. Works a treat.
Re: n ew bke pump -went back to silca
Postby lgbran » Sun Nov 15, 2009 4:58 am
Re: n ew bke pump
Postby Eurotrash » Tue Nov 17, 2009 5:00 pm
http://www.specialized.com/au/en/bc/SBC ... temId=9577
- CoffsGal
Re: n ew bke pump
Postby CoffsGal » Tue Nov 17, 2009 6:08 pm
I have a Specialized Air Tool Pro and it is easily the best I have used...and I have checked out quite a few as I do some part time work at the LBS. Wasn't cheap though...about $160 from memory.Eurotrash wrote:Specialized Airtool floor pums have won a couple of tests in German bike magazines I have read.
Emma
Re: n ew bke pump
Postby Eurotrash » Thu Nov 19, 2009 6:15 pm
I bought it because I read 2-3 large magazine tests of floor pumps and they all rated the Specialized pump as the best overall IIRC.
There's different models, Sport, Comp and Pro. Sport is the cheapset and Pro the most expensive. IIRC when I bought the Comp it was much cheaper than the Pro.
I'm not sure what thedifferencies are among the 3 models, anyone know?
- CoffsGal
Re: n ew bke pump
Postby CoffsGal » Fri Nov 20, 2009 12:17 pm
Here is a page with the...Eurotrash wrote:I have a Specialized Airtool Comp myself.
Specialized Floor Pumps range
here is the one I have...
Air Tool Pro
- casual_cyclist
Re: n ew bke pump
Postby casual_cyclist » Fri Nov 20, 2009 12:37 pm
But, it seems cheap for a good pump. Anyone have any ideas about them?
EDIT: never mind. It is cheaper in T7 anyway and there is a review:
"I was reasonably happy with this pump until I used someone else's pump. Fitting the pump head to a valve is not the best action, it's just very akward compared to the other pumps I used.
I'm looking to either fit a pump head from a different manufacturer - or just get a totally different pump."
Doesn't sound promising.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
