Tyre sizing
Tyre sizing
Postby mactype » Thu Sep 17, 2009 9:34 am
Currently the bikes fitted with Hutchinson Excel's in a 700x25c size, bike was bought used and these were on it when purchased.
Been looking around and it appears theres a larger selection of tyres in the 700x23 range.
Can I get some advice on suitable sizing (is the 23 or 25 width?) and possibly some suggested replacements?
Rims are Fulcrum 3.
thanks!
Pivot Firebird
- ghettro
Re: Tyre sizing
Postby ghettro » Thu Sep 17, 2009 9:40 am
-A lot of people will recommend Continental GP4000s
-Continental Gatorskins are also good, cheaper
-Vittoria Rubinos are good too
Do a forum search, there have been plenty of discussions on tyre choice.
- JV911
Re: Tyre sizing
Postby mactype » Thu Sep 17, 2009 9:46 am
More training.JV911 wrote:commuting, training or racing tryes?mactype wrote:Can I get some advice on suitable sizing (is the 23 or 25 width?) and possibly some suggested replacements?
Pivot Firebird
- JV911
Re: Tyre sizing
Postby JV911 » Thu Sep 17, 2009 12:15 pm
conti gatorskins are also good but more of a commuting tyre
Vittoria Rubino Pro 2 are a nice compromise between the above and make a good training tyre
- jacks1071
Re: Tyre sizing
Postby jacks1071 » Thu Sep 17, 2009 12:40 pm
I've tested extensively 19mm, 23mm and 25mm tyres and if you can get 25mm run with them on the REAR especially - they are a little heavier than 23mm but they seem to roll faster and smoother and they are less likely to puncture. For the front 23mm is fine but if you are heavy then put 25mm all round. Not a lot of companies have the 25mm available though. I have a set of Schwalbe Ultremo R's and was really happy with them in the DRY for race use only. I got caught in a race with them on when it rained and it was a wild ride ie. grip very limited.mactype wrote:Looking at putting in an order for some stuff from the UK and some new tyres look to be on the cards but not too sure on a couple of specs.
Rims are Fulcrum 3.
thanks!
Re: Tyre sizing
Postby mactype » Thu Sep 17, 2009 2:36 pm
So the difference in usage may be the Rubina Pros might last a little longer and be better if it rains?
So, would the Continental Grand Prix Attack/Force Tyre Twin Pack be ok, just I notice they have specific 22mm front and a 24mm rear?jacks1071 wrote:I've tested extensively 19mm, 23mm and 25mm tyres and if you can get 25mm run with them on the REAR especially - they are a little heavier than 23mm but they seem to roll faster and smoother and they are less likely to puncture. For the front 23mm is fine but if you are heavy then put 25mm all round. Not a lot of companies have the 25mm available though. I have a set of Schwalbe Ultremo R's and was really happy with them in the DRY for race use only. I got caught in a race with them on when it rained and it was a wild ride ie. grip very limited.
Pivot Firebird
- m@
Re: Tyre sizing
Postby m@ » Thu Sep 17, 2009 2:50 pm
- Zynster
Re: Tyre sizing
Postby Zynster » Thu Sep 17, 2009 3:22 pm
I've posted a question on Wiggle to find out if the black 700x25s are black chilly.
Stay tuned.
- sblack
Re: Tyre sizing
Postby sblack » Thu Sep 17, 2009 8:16 pm
m@ wrote:Would be nice if Conti would make the GP400S in anything other than 23... If you believe the marketing hype about their black chili compound ("rolling resistance is reduced by 26%"), I wonder whether the lower pressure of a GP4000 25 would outweigh the benefit of the black chili in the GP4000S 23 - just in terms of rolling resistance..?
I had the question of the difference in the GP4000 and GP4000S when I last purchased tyres so I contacted Continental through their website and they informed me the only difference is the label. I ordered a pair of 700x25 and have been very happy with them. Packaging definitely says they're black chilli as well.Zynster wrote:Conti make the GP4000 in 700x25, and they state that the black GP4000 uses black chilly.
Stay tuned.
- twizzle
Re: Tyre sizing
Postby twizzle » Thu Sep 17, 2009 8:41 pm
The downside is that the wet puncture protection sucks, but they are excellent in the dry.
- jacks1071
Re: Tyre sizing
Postby jacks1071 » Fri Sep 18, 2009 10:57 pm
I've worn 3 sets of Force/Attack combo down to the canvas - great tyres. Mine were the older version though which was a 19mm front and a 23mm rear. I have not ridden the new model with the black chilli rubber but I can only assume they would be even better.mactype wrote:So I presume the difference between say the Conti 4000 and the Rubina pro's are tread design and compounds.
Personally I train on Vittoria Zaffiro tyres as I get them cheap, they rarely puncture and they last for a lot of KMS. They have a wire bead which I find makes getting them on and off easier when you do puncture and I run a tyre liner in the back (I hate punctures and rarely get them at 67kg..)
For racing I currently have Hutchinson Fusion 2's (tubeless), Zipp Tangerinie, Vredstein Tri Comp Tubular, Schwalbe Ultremo R - all those models are excellent puncture resistant race tyres. I wouldn't train on any of them as they are a bit expensive to cut up... You want to be a pretty competitant bike handler to use the Ultremo R's in the rain as well - I wouldn't do it on purpose.
- Aushiker
Re: Tyre sizing
Postby Aushiker » Sun Sep 20, 2009 11:35 am
I am a fan of the Continental Grand Prix 4000S (with Black Chilli) but can't notice the difference between them and the Continental Grand Prix 4000. I don't race but do Audax and group rides on these tyres.
I used to commute on Gatorskins and would never use them again.
Regards
Aushiker.com
Re: Tyre sizing
Postby backofthebunch » Thu Nov 12, 2009 9:46 pm
I'm new to this and wanna make sure.
- thirtytwospokes
Re: Tyre sizing
Postby thirtytwospokes » Thu Nov 12, 2009 10:07 pm
Without knowing what rims, I'd say almost certainly yes. Most road rims can accommodate 23s to 28s, and possibly wider.backofthebunch wrote:if i have currently 700 x 25 tyres am i able to replace them on the same rim with 700 x 23 tyre?
Re: Tyre sizing
Postby backofthebunch » Thu Nov 12, 2009 10:18 pm
yeah thought that, thanksthirtytwospokes wrote:Without knowing what rims, I'd say almost certainly yes. Most road rims can accommodate 23s to 28s, and possibly wider.backofthebunch wrote:if i have currently 700 x 25 tyres am i able to replace them on the same rim with 700 x 23 tyre?
Users browsing this forum: Amazon [Bot]
