Chain cleaning
• Page 1 of 2 • 1, 2
Chain cleaningG'day
I have taken a look at a couple of the suggested bike maintenance websites and both suggest using a citrus based de-greaser for cleaning chains. Is such a beast available here Australia or preferably WA? I was in Bunnings today and they just had Diggers brand. Would this be okay? Other suggestions? Regards Andrew
Don't know about Bunning's option. Citrus degreasers have been seen by me at every LBS I've been to. It's better than some of those industrial degreasers on the ground of being biodegradeable.
Don't worry about Sheldon's April Fools dig. Just for light reading. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
The Bunnings Diggers degreaser is solvent ... get along to Repco Auto and pick up Lightning Tuff cleaner/degreaser citrus base, 750ml non-aerosol spray pack, really great result, can remove the top and pour into a chain cleaner or other container or use as a spray on. About $10 from memory.
I've been using kerosene for a few cleans as most of those spray de-greaser contain health warnings.
It takes about 10 spin cycles through the chain cleaner (refilling each time) to get the majority of the crap off an the rest I do with a rag. 1x1ltr bottle ($5 from memory) will do about 6-8 cleans.
G'day
Dropped into TBE (LBS) today and they had a citrus degreaser (orange can) selling for $32.00 for 600 ml. Seems expensive. Does it sound right? Torpedo7 have a product called BLUBIKE Bio Chain Cleaner selling for $8.00 for 250 ml which is quite a bit cheaper than TBE. Anyone tried this? Regards Andrew
Thanks, yeah I considered the postage and thought if it was good I would include it another order. Of course I placed a order last night didn't I Regards Andrew
that is why i said ... get along to Repco Auto and pick up Lightning Tuff cleaner/degreaser citrus base, 750ml non-aerosol spray pack, really great result, can remove the top and pour into a chain cleaner or other container or use as a spray on. About $10 from memory.
Ahh sorry twowheels. Overlooked your good advice. Consider me duly smacked.
I have a Repco nearby (but not on a good riding road) so will check it out. Thanks Andrew
drop the chain in an old gatorade bottle of white spirit. Shake (not stir). Remove and wipe. Put back on bike and lube
G'day
Twowheels I took your advice and dropped into Repco this morning and picked up Grime Goblin Cleaner/Degreaser which is a citrus based degreaser. I got the 4 litre container for $16.00. They had a one litre product for $10.99 but the Goblin seemed a better deal, assuming of course it is any good! So thanks for the suggestion. Regards Andrew
I've seen the Grime Goblin. I think the Tuff is just rebadged for smaller packaging, tried the Tuff first to make sure it works, plus included the spray pack. Let us know how the Grime Goblin goes, then I'll repackage it in a 250ml container and flog it for $5 ... I'll say it is made from new season cumquats, hand picked by virgins on gold plated unicycles!
BTW, shop by volume isn't everything when it comes to citrus degreasers. Some products needs to be diluted (eg. 1:5 to 1:10), whilst others are meant to be used straight.
Well there is nothing to suggest on the container that diluting is needed or suggested, so what criteria do you use to determine this? Also chain cleaning is one but use. Even so paying $4.00 per litre is heaps better than $11.00 for 600 mils in my view. Regards Andrew
I don't know which product you refer to but the fact that it doesn't require dilution suggests to me that it's used without dilution. The one I have requires dilution prior to use. In any case, it's something to be aware of when shopping and trialing different products. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
See early post in this thread.
Okay, now I see where you are coming from. Hadn't consider that. Will do if I ever use up this container. Regards Andrew
The link you provided all say ready to use formula, we might just have caused a rush at repco auto!!!
Lightning Products - Cleaners> Grime Goblin Cleaner/Degreaser See full size photo Price: No Price Availability: in stock Prod. Code: 502S, 502L,502N & 502T Grime Goblin Cleaner/Degreaser Grime Goblin Degreaser utilises citric instead of petroleum solvents, is non-flammable, biodegradable and is a quick break degreaser. Grime Goblin Degreaser is ideal for cleaning and degreasing engine bays, workshop floors, walls and equipment. Grime Goblin also has dozens of domestic cleaning applications like removing soap scum and body oil from showers, cooking oil and animal fat from BBQs and even emulsifying stains from carpet and upholstery. Available in: SIZE Description PRODUCT CODE COMMENTS 750ml High Foam Atomiser Bottle 502S Ready to Use Formula 1lt 1lt Screw Cap Bottle 502L Ready to Use Formula 4lt 4lt Clear Plastic Container 502N Ready to Use Formula 20lt 20lt Plastic Barrel 502T Ready to Use Formula
Return to Buying a bike / parts Who is onlineUsers browsing this forum: Bing [Bot], Google Adsense [Bot], liamb, rifraf |
