Ok thanks.
As long as its safe to do so. There are far too many numbers been thrown around.
buying a pump-gauge or no gauge?
• Page 2 of 2 • 1, 2
The 35-40 range is normally safe for high volume tyres. You ought to be able to at least go to the bottom of the recommended pressure range on the tyre.
If you're riding on road with fat knobblies then putting more air in can make it easier.
If you think 55psi is low, try one of these...
It's the Hanebrink ETB, IIRC, they recommend about 15psi, tops. Shaun ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
If its gets any colder, I may have to order one of those babys I've got stuff on ebay
Re: re
The shop I work at have them for a couple of dollars. let me know if you want one and I'll pop one in an envelope for you. Wayne
reThanks for wanting to help, I actually already got one, the servo nearby has a gauge that goes to 100psi (tested it with the mtb)or more but when I tried with the presta valve using the adapter I could put in air but couldn't get the gauge to work, I think its not hitting the tip of the valve or something.
Re: re
you probably know this, but if you're running the standard knobblies on the MTb, you really don't want to be riding at 100psi... should be somewhere about half that.
Return to Buying a bike / parts Who is onlineUsers browsing this forum: Google Adsense [Bot] |
