Sigma 1606 DTS
Rusty Bucket
Sigma 1606 DTS
Postby Rusty Bucket » Thu Jul 26, 2007 4:15 pm
Hi,
I recently purchased a 1606 DTS and the speed sensor just attaches to the front fork using an O-ring. Trouble is it doesn't seem tight enough to hold the sensor securely. Ultimately vibration causes the sensor to move, usually into the magnet or spokes.
Has anyone else had this sort of problem and what did you do to get it fixed
MichaelB
Postby MichaelB » Thu Jul 26, 2007 4:38 pm
Use a smaller o-ring (the packaging supplies a couple of sizes.
Or, move the sensor further up the fork to a thicker part.
If that isn't any good, head down to the local fastener place (Universal, Coventry, Repco etc) and buy a few O-Rings to suit
europa
Postby europa » Thu Jul 26, 2007 4:41 pm
G'day Rusty, welcome to the peleton.
Usually you have the opposite problem with those O rings - there weren't two sizes were there? A large one for the handle bars and a smaller one for the fork?
Forks get thinner towards the drop outs, so sliding the sensor further up the fork might be a solution.
Swearing a lot won't fix it but it might ease the frustration.
If none of these work, a bit of double sided tape will do the trick (still using the O ring, the tape is just there to add a bit of grip). Failing that, see if you can strap the sensor in place with zip ties.
europa
Postby europa » Thu Jul 26, 2007 4:42 pm
doncha hate simutaneous posts :roll:
gsxrboy
Postby gsxrboy » Thu Jul 26, 2007 4:46 pm
Random suggestions -
Maybe you could cut up a bit of an old tube and 'line' the inside of the mounting point with it to help with the vibration and to 'thicken' it up a bit to put a bit more pressure on the o-ring. Try a higher position on the fork leg, if possible, where if might be more vibration resistant and it might fit the contour of the wireless sender a bit better.
Edit - mostly beaten with the fork leg suggestion, that will teach me for doing work while foruming :p
Rusty Bucket
Postby Rusty Bucket » Tue Jul 31, 2007 6:45 pm
Thanks for all the suggestions. Swapped to the smaller O-Ring and seems to hold firm after 160km of riding. Thanks again
tuco
Re: Sigma 1606 DTS
Postby tuco » Thu Aug 02, 2007 8:34 am
Rusty Bucket wrote:Hi,
My worry is the O ring will break and there goes the sensor!
Cable ties rule.
I think we can do better. I KNOW we can do better.
europa
Re: Sigma 1606 DTS
Postby europa » Thu Aug 02, 2007 8:37 am
tuco wrote:My worry is the O ring will break and there goes the sensor!
The O rings on the Europa's computer are some years old now and have been moved around a few times (including bike swaps), yet seem to have withstood the ravages of time quite well. I don't think it's a problem though I understand what you mean - I have a similar concern.
Users browsing this forum: gtext
