Melb commuter - Merida spresso 300D?
Postby gnik » Sat Jan 09, 2010 4:41 pm
I ride to the Melb CBD from Clifton Hill pretty much every day, either along the Merri / Yarra paths or by road.
My Shogun Metro SE is ready for retirement & I've been looking at a replacement <$1k that is
durable, comfortable, low-maintenance and fast-ish (roughly in that order). I've test ridden Scott Subs, Scott Sportster, Kona Dew Plus, Cannondale Quick 5, Metro SE and Merida spresso 300D.
Of these, the Merdia seems well spec'd & a good buy at $899. Before I buy, has anyone had experience with these bikes? Or any other recommendations / comments?
Note: I broke my back a couple of years ago, so comfort (i.e. slightly upright position) is important. Also I'm steering away from sprung forks as I reckon I won't use them. Oh, and I'm told I ride fairly agressively.
Thanks in advance...
Re: Melb commuter - Merida spresso 300D?
Postby gnik » Sat Jan 09, 2010 7:33 pm
Merida S-Presso 300-D 2009:
http://www.bikeexchange.com.au/bikes/sh ... esso-300-d
Frame S-Presso Alloy
Size 45-50-55-60-45L-50L-55L
Fork Alloy Straight Disc
BB Set Shimano UN26
B-Lever attached
Brake-F Tektro Auriga Comp 160
Brake-R Tektro Auriga Comp 160
B-Cable 0
C-Housing MTK700 SP40
Chain Shimano CN-HG53
Chainguard Attached
Chainwheel Shimano M442 44-32-22 CG
DERA-F Shimano Deore 31.8 T-Swing
DERA-R Shimano Deore Top Normal
Freewheel Shimano CS-HG50-9 11-32
Grip Comfort Pro
H-Bar XM Comp CEN Flat 600
H-B Stem XM Speed CEN 7
Head Set CONOID A-HEAD
Hub-F Disc Alloy
Hub-R Disc Alloy
Pedal XC Alloy
Rim Alex DP17 Disc Black
Saddle Selle Royal Freccia
Seat Clamp Merida Aero 32 Allen ST
Seat Post S-Presso Comp CEN SB20 27.2
Shifter-F Shimano Deore rapidfire
Shifter-R Shimano Deore rapidfire
Spoke Stainless Black
Tire-F C1447P 35
Tire-R C1447P 35
Hardware Stainless
Scott Sub 20 2009:
http://www.bikeexchange.com.au/bikes/sh ... ott-sub-20
WEIGHT
11.60kg/ 25.265lbs
FRAME
New Evo/Aero hydroformed alloy tubing w Evo D/O 26"
FORK
Scott SUB straight alloy fork
26“ or 700C disc only
HEADSET
Ritchey OE Logic Zero, semi integ.
DERAILLEUR (REAR)
Shimano Alivio RD-M410 SGS
24 Speed
DERAILLEUR (FRONT)
Shimano FD-M310
34.9mm clamp
SHIFTERS
Shimano SL-MC 40-8
w/gear indicator
BRAKELEVER
Shimano BL-M 486
Disc
BRAKES
Shimano Deore BR-M 486 disc
w SM-RT53 CL 160mm
CRANKSET
Shimano FC-M 411
48x36x26 T w CG BB-SET
Shimano BB-UN 26 / 68-113mm
HANDLEBARS
Scott X-Rod OS ,
580mm, 5° bend
H'STEM
NVOâ„¢ 3 OS Stem / 4 bolt
40mm adjustable
PEDALS
Wellgo 998 A
SEATPOST
Scott Comp HL-SP 209
31.6mm
SEAT
Scott SUB
HUB FRONT
Scott Comp Disc CL
HUB REAR
Shimano FH-RM 65 CL
CHAIN
Shimano HG 40
CASSETTE
Shimano CS-HG30- 8I
11-30T
SPOKES
stainless black, 14G/2mm
RIMS
Alex SUB 26", 32H,
black anodized, for disc
TIRES
Continental Sport Contact
26“ x 1.3 or 622-32C
- trailgumby
Postby trailgumby » Sat Jan 09, 2010 7:58 pm
It has the better drive train, though. The Alivio on the Scott is not a long term prospect. It will not be very nice to use and will be a challenge to keep in tune.
If you can get the next equipment level up you'll enjoy the bike a lot more.
Postby gnik » Sat Jan 09, 2010 11:16 pm
Thanks for the reply. Are you saying the Tektro Auriga hydro discs lack stopping power? I'm about 67-68kg by the way.trailgumby wrote:Tektro Auriga hydro discs are pretty ordinary. Unless you're a lightweight rider, that would disqualify the Merida for me right there.
The other option I'm considering is the Scott Sub 30 2010 which has all Deore running gear + Tektro / SCB-36 A V-Brakes. Any thoughts on this?
Re. next level up, I really don't want to pass $1k. Can you recommend something else at my price point?
- Cranky Jim
Postby Cranky Jim » Sun Jan 10, 2010 12:12 am
- Aushiker
Postby Aushiker » Sun Jan 10, 2010 4:11 pm
Have you looked the Giant CRX range? I am not sure that you really need disks (especially low end ones) or the weight they add.
The only possible downside is the limitation on tyre width. They come standard with 28 mm but I am not sure how wide you could go.
Regards
Aushiker.com
Postby gnik » Sun Jan 10, 2010 11:03 pm
Thanks for the comments re. the performance of the Auriga discs (this also putting me off the Merida). Perhaps the 2010 Scott Sub 30 is a better bet than the Merida & 2009 Scott Sub 20 in the OP. The 2010 Scott Sub 30 is spec'ed like the 2010 Sub 20, but with cheapo v-brakes:
2010 Scott Sub 30
Frame
New 2010 hydroformed alloy tubing w Evo D/O 700C
Fork
Scott SUB straight alloy fork 700C
Headset
Derailleur (Rear)
Shimano Deore RD-M592 SGS, 27 Speed
Derailleur (Front)
Shimano Deore FD-M590 34.9mm clamp
Shifters
Shimano Deore SL-M 590, w/gear indicator
Brake Levers
incl. in shifters
Brakes
Tektro/ SCB-36 A V-Brakes / blk
Crankset
Shimano FC-M 443 48x36x26T, w CG
BB-Set
Shimano BB-ES 25 / 68-113mm
Chainguide
on crankset
Handlebar
Scott OS , 580mm, 9° bend
H'stem
Scott, JD ST 66 OS 31.6, 4 bolt
Pedals
Wellgo 127 S
Seatpost
Scott Comp HL-SP 209 31.6mm
Seat
Scott SUB SCT 19
Hub (Front)
Scott SCO 31
Hub (Rear)
Shimano FH-RM 30
Chain
Shimano HG 53
Cassette
Shimano CS HG 50-9 11-32
Spokes
Stainless black, 14G/2mm
Rims
Alex SUB 7, 00C 32H, black anodized, cnc
Tires
Continental Sport Contact 622-32C
- Aushiker
Postby Aushiker » Mon Jan 11, 2010 4:05 pm
Hignik wrote:The 2010 Scott Sub 30 is spec'ed like the 2010 Sub 20, but with cheapo v-brakes:
My CRX1 has/had Tektro RX-5 85mm mini v-brakes which where/are okay. Going to Kool Stop pads improves braking by all accounts. Brakes are also a relatively cheap item to upgrade if you so wish.
Regards
Aushiker.com
Postby gnik » Mon Jan 11, 2010 5:10 pm
I'm also interested in trying some of the bikes that use more of the road bike componentry as I think the gear ratios may suit my riding style more (have I got this right - I tend to run out of higher gears & rarely use the lower ones?).
From what I have seen & read, bikes around my price point (<$1k) that would be worth a look are the Orbea Spectrum and Progear RS-40 (thanks to other thread! (maybe another bulk-buyer?)). I'll also look at the Giant CRX 2 and Jamis Coda Sport tho' these are pushing my price-limit.
This is a steep learning curve for me; hence any comments on the relative merits of these bikes are very welcome....
- richiec
Postby richiec » Tue Jan 12, 2010 11:00 am
Postby Runjikol » Tue Jan 12, 2010 9:21 pm
Postby gnik » Tue Jan 12, 2010 10:10 pm
Genuine question: why do you recommend disc-brakes for commuting? Others have suggested heavy & unnecessary...Of those I've tried, the Merida, Scott Sub 20 & Kona Dew Plus had discs-brakes, the former two hydraulic & the latter cable.Runjikol wrote:Highly recommend disc-brakes for commuting. All your bike choices seem solid (but I think you should jump up the range to disc-brakes). Best test is getting your butt on the bike and going for a spin. You'll know the one you want after that.
Had a brief spin on an Orbea Spectrum and Progear RS-40 today (my 5YO daughter was in tow & too hot for a serious test). Both seemed worth a second look. I can see why others are impressed with the Progear - seemed pretty nimble after 12 years of hybrids. I liked that the Orbea had an adjustable head stem (I compressed a couple of vertabrae in 2007 & need to sit a little upright to avoid lower back pain), tho' I assume these can be added to most bikes.
Postby Runjikol » Tue Jan 12, 2010 10:36 pm
IME disc brakes are so much better in inclement weather that I could never go back to rim brakes by choice.
In dry weather, well... just awesome to the point of being unnecessary and Avid Juicy Three's are not high-end at all.
Try them for yourself and see what you think. It's the best way.
Postby Poutama » Fri Jan 15, 2010 10:16 am
Melb Com,richiec wrote:Eyeball Norco VFR series bikes. Though they'd gone back to V-brakes for 2010 models. You might find an 09 VFR1 or VFR2 floating around with disks.
Bike Hub has 2009 VFR Disc 1s and 2s on special at the momment as I believe they are one of the only stores that can sell Norco now. I'm about to get one to replace my old Giant crx2 if all goes well.
I asked Bike Hub here in bris to get one in so I could test it out and they were cool
You might want to jump in soon though as there arn't that many 2009 models left in the country.
Postby gnik » Fri Jan 15, 2010 10:55 am
Thanks, I'll check it out. As a matter of interest why are you replacing your CRX2?Poutama wrote:Melb Com,richiec wrote:Eyeball Norco VFR series bikes. Though they'd gone back to V-brakes for 2010 models. You might find an 09 VFR1 or VFR2 floating around with disks.
Also, I tried a 2009 Merida Speeder T2 this morning which has more of a road bike set up than the S-Presso - Tiagra running gear, Mavic rims, 52 tooth chainwheel...felt light & responsive, but hopefully tough enough to handle potholes & cobblestones.
Does anyone have any comments on this bike? Specs below:
Frame Speed Alloy
Fork Speeder Lite
BB Set Shimano UN26
B-Lever XM COMP
Brake-F V-Brake Linear
Brake-R V-Brake Linear
B-Cable MTK720 2P
C-Housing MTK720 Sp40
Chain Shimano CN-HG50
Chainwheel FSA Vero 52-42-30
DERA-F Shimano R453 34.9
DERA-R Shimano Tiagra GS
Freewheel Shimano CS-HG50-8 11-25
Grip XM Comp
Head Set M10 Neck
Hub-F Alloy QR
Hub-R Shimano 2200
Pedal XC Alloy
Rim Mavic CXP22N BLK/NC
Saddle XM Cross Sport
Seat Clamp Merida Aero 35 Allen ST
Seat Post XM Speed CEN SB20 31.6
Shifter-F Shimano SL-R440-3
Shifter-R Shimano SL-R440 8s
Spoke Stainless Silver
Tire-F Kenda Kwick Trax 32 ref.
Tire-R Kenda Kwick Trax 32 ref.
Hardware Stainless
Postby Poutama » Fri Jan 15, 2010 3:54 pm
This bike seems to fit the bill. Also the disc brakes are a bonus. Though havn't tested it yet
I've been quoted $1195
After Christams is a great time to get decent deals as well.
