tri bars
Postby Mulger bill » Sun Aug 05, 2007 8:08 pm
I've got one of those 'puters stated, the mounting bracket is adaptable for bar or stem mounting 8)
Shaun
thomas_cho
Re: re
Postby thomas_cho » Sun Aug 05, 2007 10:35 pm
stated wrote:I noticed before a lot of people have mounted their Sigma 1606L on the stem. I have a question, is it now pointing to the side? if not how to make it point straight?
Sorry for going off topic.
Hi there, the mounting plate for the computer can be unscrewed from the base. You can then rotate the mounting plate.
Let me know if you need a pic.
stated
Re: re
Postby stated » Mon Aug 06, 2007 6:56 pm
Let me know if you need a pic.[/quote]
I've looked at those screws before, problem is they are in rectangular shape, so I don't see how I can turn it 90degrees, only 180degrees.. :?
thomas_cho
Re: re
Postby thomas_cho » Mon Aug 06, 2007 8:31 pm
stated wrote:Hi there, the mounting plate for the computer can be unscrewed from the base. You can then rotate the mounting plate.
I've looked at those screws before, problem is they are in rectangular shape, so I don't see how I can turn it 90degrees, only 180degrees.. :?[/quote]
I guess a picture would be clearer, you may not have noticed the additional screw holes on the computer mount.
The picture shows the base unscrewed from the computer mount, you can rotate the base 90 degrees.
Postby Mulger bill » Mon Aug 06, 2007 8:40 pm
It does work Stated, here's my unit...
I'll check the manual when I get home.
Shaun
stated
Postby stated » Tue Aug 07, 2007 1:10 pm
I guess a picture would be clearer, you may not have noticed the additional screw holes on the computer mount. [quote]
thanks for that champ its all clear now :oops:
