Will 10 speed triple front derailleur work on an 8sp triple?
darrenbridges
Postby darrenbridges » Fri Jan 29, 2010 4:52 pm
G'day,
I'm looking at getting a new front derailleur for the current 8 speed triple crankset. The Shimano 105 FD-5603 is a 10 speed front derailleur but will this have any compatibility issues with the chain or cassette? I suspect being a triple would be enough but it's advertised as 10 speed and I just wanted to check if it would be ok?
Darren
jules21
Re: Will 10 speed triple front derailleur work on an 8sp triple?
Postby jules21 » Sat Jan 30, 2010 10:36 pm
yes should work. derailleur just does what it's told, doesn't know how many speeds. all shimano derailleurs apparently have the same lever ratio.
darrenbridges
Postby darrenbridges » Mon Feb 01, 2010 12:36 pm
Thanks for the help Jules, cheers.
Darren
kukamunga
Postby kukamunga » Mon Feb 01, 2010 1:19 pm
10 speed FD and chain is narrower. You may find 8 spd chain rubs on FD when using two inner and two outer rear cogs
Users browsing this forum: CKinnard
