Magic ShineRe: Magic ShineJust got a 'Cree Q5 240lumen' torch type light for $19, Fantastic, really nice quality AND a solid bracket (very unusual on ebay lights) and makes the 1W lights seem like riding along with a lit match. I'm still keen on a magic shine type light but only if they have a wide beam, a supernova 10cm across is no use.
Re: Magic Shine^The magic shines have a very wide floody beam. In fact so floody they don't throw all that far which is ok off road but not so much on the bitumen when you don't want to blind drivers and other riders (so I've read and seen from beam shots).
I've just ordered a couple of torches for cycling too after spending hours and hours reading up on all manner of things torch related; LED data sheets, drivers, hosts, drop ins, heatsinking,... - you name it. They won't be here for probably 3 or 4 weeks, but all reports indicate they can individually put the magic shines to absolute shame on high (though they can only run on high for a limited time as they're pumping out 10+W of heat) and the build quality should be a lot better. Even though they use the same Cree XM-L T6 emitter as the 808e, they should each outclass it as well, especially for road cycling thanks to more throw and a better beam pattern from the reflectors. I'll be using them on medium so they don't burn up, but that will still be more than the MSs and for only $10 more than the 808e including four 18650 protected Li-Ion batteries, a charger and a battery case shipped. Mounting is simple, sturdy, quick to remove/install and free with hose clamps, a rubber band bracelet and some old inner tubes. This has benefits in being able to carry the lights with me so they aren't flogged and being useful off the bike. I can even run one of the torches off standard AAAs if I need to (not for long though, and probably not on high). It's not actually quite an ideal setup with regards to torch form factor (read heat dissipation) and batteries (life) but thanks to P60 drop ins and 18650s being the market standard it's the best you can get for your dollar at this price point.
Re: Magic ShineAlways worth remembering that a torch is useful off the bike, while a bike light isn't. Any reason for thieves to borrow your lights is a bad one!
Review after the rain in Sydney for the last few days, which has been brutal at times. The water WILL get into the connector, even if you are strategic and aim the male plug upwards, but it won't stop it working at all. I would recommend disconnecting at night to let it all dry out. Long term longevity of this setup? No idea but currently I'm not upset. It DEFINITELY got a heavy workout and you don't need to worry about it failing from one or two heavy days of rain. I still plan on mounting them permanently to the bike, it will be interesting to see it all coming together then.
Re: Magic Shine
Have you tried o-ring lube Xplora? A little on the male side of the connector not only makes it a bit easier to get on and off but has also sealed it well. No moisture even in heavy rain. No need to get any fancy dive light silicone lube I use hyrdoseal from Bunnings which was just a couple of bucks. Even works on the o-rings in the light head and my helmet mounted torch. I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
Re: Magic ShineHydroseal is a silicone based lube isn't it? If your light has silicone o-rings it is not a good idea to use silicone lube. The lube will make the rings swell and degrade, which can reduce their water resistance and make it rather difficult to unscrew.
Re: Magic ShineUm, silicone based is what you want for o-rings because it doesn't degrade the rubber. Petroleum based lubricants on the other hand do. You could be right, but I'm fairly certain you've got your greases backwards.
Re: Magic Shinesilicone grease on rubber o-rings is fine. Petroleum grease will destroy rubber o-rings in short order.
silicone grease on silicone o-rings on the other hand is not fine.
Re: Magic ShineOk, checked the manual - I'm wrong. Silicon grease is "3) Sometimes ok for static applications", but definitely not 1) Fine, same for silicone oils. Other silicate compounds are mostly 2 or 3.
The moar you know...
Re: Magic ShineWhat is it about lubricants that attracts such passionate views, whether it is engine oils, bike chains or o-rings?
For clarification the connection I was refering to does not appear to have a seperate o-ring - it is just moulded plastic with an interference fit I have no idea if Hydroseal is a silicone based lube - there is nothing on the tube indicating one way or another. I know that the brown o-rings in my light have neither swollen nor degraded. I would be amazed if the o-rings on a cheap chinese bike light are silicone - The lights are built down to a cost and I am betting that the brown o-rings are made from whatever is cheapest - last time I checked silcone o-rings were about 3 or 4 times the price of other materials such as ntirile.
Care to share a reference to the "manual" you are referring to. Unless I am mistaken, the o-ring in a bike light is static - once installed there is no movement between the o-ring and the parts. I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
Re: Magic Shine
Just to report back - I tried this method of inverting the light (so it was mounted to the underside of the handlebars) and it did work much better. It sort of rests on brake/shifting cables (as they route via the underside of my bars) this way but they don't seem to affect it. Thanks for the tip!
Re: Magic Shine
http://www.parker.com/literature/ORD%20 ... ndbook.pdf Sometimes Ok implies don't do it unless you have to because it'll almost certainly cause issues, unless you specify a short service life for the part - which is obviously a bad thing.
Re: Magic ShineI bought this one off ebay and it turned up yesterday. http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
Tried it for the first time this evening and OH MY GOODNESS it is incredible. On the surface it looks pretty solid and the light just blew me away, super wide beam with a large spot in the centre which gets it a fair way down the road and the sheer quantity of light is fantastic. My Cree Q5 (claimed as 240lumen) which i thought was SOO bright was completely overwhelmed. Even if this only lasts a few months it will be worth every penny as i have literally seen the light and can now appreciate a 100ish lumen light. When man invented the bicycle he reached the peak of his attainments- Elizabeth West.
Re: Magic ShineIf your battery pack looks the same as the picture, make sure that water can't get at it. Not even a drop. It's not waterproof, and reports are that it is instant death for the battery. Either way... I ran my light this evening down a bike path I'd never travelled before, ample light for the purpose although I will say that I can see why you'd get the 1400 lumen alien light with the main lamp and 2 auxiliary lights, because seeing around the corner a little bit is very helpful.
I've decided that you can't have too much light. The extra confidence you get from being able to see at night is worth every penny, and my eyes aren't fantastic so somewhat fuzzy eyes plus dim light makes avoiding potholes etc almost impossible, particularly if you're knackered already.
Re: Magic Shine
About how long did it take for delivery? .. I am considering buying one as a gift for someone's birthday in 16 days time....
Re: Magic Shine
Crikey, that's a good price. About $20 odd cheaper than Dealxtreme !!
Re: Magic ShineI had one of the P7/MJ-808 lights ( http://www.torpedo7.com.au/products/R7LI4N0LI ). It's on its last legs - battery life is down to 45 minutes and the light switch doesn't work anymore. I was looking at one of the MJ-872 lights, but considering the price of the eBay one just posted, might just go that route instead.
Is there a good middle ground at the moment? I'm really after battery life more than anything - I do a bit of cycletouring, so being able to get 10-20 hours would be great (of reduced brightness obviously
Re: Magic ShineWhoops, and the other thing I meant to ask - if I do just get a replacement, what's the recommended way to waterproof the battery pack? I usually carry it in my jersey pocket, with the light mounted on my helmet...
Re: Magic ShineBought it on the 26-7 and got it on the 3rd, pretty quick i reckon. I'm definitely not expecting it to be waterproof, it might look reasonably good quality on the surface but there's no point risking it, plus i can't stand riding in the rain anyway so not a problem.
Re: Magic Shine
Cheaper than DX used to be, now less than US $45 I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
Re: Magic ShineHow does the cree T6 compare to the ssc P7? is the battery life much different?
Re: Magic Shine
Thanks..! Have bought one now... hopefully they deliver to me as quick as they did to you.
Re: Magic ShineWeird battery issue. BUT I have dropped the batteries a few times from the bike saddle to the biek rack... the jury is out just now. Take care of your batteries, bit hard to blame MagicShine for my abuse.
Re: Magic ShineDepends on what battery you have! If its the older style with open ends silicone them across the ends and where the wire exits. If it is in a rubber pouch no need same as the new big with the voltage check. I consider mine as water proof as any other lights and they have never leaked or let me down.
Sent from my MB525 using Tapatalk
Re: Magic Shine
What's your wierd battery issue? I have had to resolder a few connectors in mine so may be able to help. I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
Return to Buying a bike / parts Who is onlineUsers browsing this forum: boss, thomashouseman |
