DISC BRAKE HELP
• Page 1 of 1
DISC BRAKE HELPHi guys,
i got the TEKTRO brake system on my bike and i was just wandering is it normal if i cant get my back brakes to lock up?Also why would that be the case if i cant lock them up if it isnt normal...? Thanks Hope to hear your responses
If you can't get your brakes to lock it is NOT normal, it is dangerous to ride with brakes that cannot effectively stop the wheel! If you can pull the lever all the way to the bar then they are not properly set up.
With cable disc brakes, you need to wind the inside pad out so it is only just clear of the rotor, then adjust the outside pad and cable tension so it is also just clear. When you pull the lever it should flex the rotor very slightly into the inside pad and further pull on the lever will grab the disc harder. If you are not confident setting up your brakes yourself then take it to a bike shop and ask them to help you. If you look around on the web you might be able to find a service manual for the brakes you have, which would show specifically which parts you need to adjust.
liek i can stop in time,like straight away but they are just not locking up and i have adjusted the lever....
G'Day Croat
I'm pretty sure you run cable discs, it sounds like it could be a cable stretch issue. Your bike is still very new, maybe try the dealer? If you want to do it yourself... First up you should be able to download a manual that'll show you what's what, then check out sheldonbrown.com or park tools.com for lots of handy maintenance tips. Have a go and let us know. Shaun ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
It's not weather you can stop in normal circumstances or flat ground, it's when you're on a downhill and you find yourself still picking up speed with the lever pulled all the way to the bar. If you can pull the lever all the way to the bar, then it's not braking as hard as it could be. If you're on road you mainly need the front brake, off road you definitely need both. If you look at the rotor when you put the rear brake on, does it move much before it contacts the inner pad?
ill get back to your question later but i mean my brake stops perfectly and everythign it just never locks up,but it does have that stoppping power to make me stop goign down a hill,anyway ill go now and have a look at it and ride it a bit....
Croat4Ever,
Can you describe exactly what happens when you pull the lever? Does it go all the way to the bar? Does it come up solid but still not lock up? If it doesn't lock, they are not set up properly: there is no escape from that fact. It could be oil on the brakes as Bnej said (good call Bnej), but it could also be a "feature" of Tecktro levers - they have a system where the amount of cable movement when you squeeze the levers can be varied. If you have a little knob on the levers it could be that you have the pull set inappropriately and it needs adjusting there. If you can post a pic of your lever and your callipers it might help us help you. MountGower, he would also need a new wheel-set to fit V brakes (disc rims don't have a braking surface) and he may not have the V-brake lugs on the frame and forks. Maybe it's also just as good to have discs and know how to use them ..... Cheers, Graeme Think outside the double triangle.
--------------------------------------- My web site: www.scenebyhird.com --------------------------------------- The Bicycle Transportation Alliance
just came back form my ride...the results are in:P
when i tried to skid on the grass the brakes sort of skidded liek it was just grabbing...if that helps...whether the bike shop put some lub o nit and it just has to settle in but i am not sure i will get some pics up now....
There are plenty of advantages to disc brakes. Some are indeed more fiddly, but not that much more. When they're properly set up you get a nice light touch, easily modulated braking action. They can get hotter without degrading performance as much, and you can't puncture your tube by overheating your rim. The rotor is generally out of the crud more too. That said, many bikes have poor quality disc brakes now just for the bling factor - Giant are especially guilty of this, as they don't make any bike above the entry level with V brakes.
There should not be any lube on your brakes. And it should not "sort of lock up on the grass" - it should be quite definite. The reason people put disc brakes on MTBs is the supreme stopping power they exhibit - there is no maybe about it. Your brakes are not functioning correctly.
Email them to me and I'll sort it out for you: graeme.hird at gmail dot com. You do need a place to drop them on the net. Think outside the double triangle.
i know they arent functioning properly but they were fine 2 weeks ago and i got it serviced and they changed my brake levers to go softer and from the non everythign went down hill...
Here are the photos of the brakes:
The levers aren't Tektro, so the knob I was referring to is not there. Can you send us a close-up of the gap between the pads and the rotor please? It might be hard to capture with your camera. When the callipers are set up properly, there should only be enough room for one or two sheets of paper to slip through the gap. If there is more than that, the LBS has not done the job properly. What they may have done to satisfy your request is to wind the knob on the brake lever (1st photo) back so that it supplies lots of slack in the cable. If that's the case, it's an easy fix - just wind that knob back out until you're happy with the feel of the brakes. This may well be what they have done, since both the knobs controlling cable slack (on the lever and the calliper) are in the extreme slack position. Cheers, Graeme Think outside the double triangle.
yeh its like 2-3 sheets of paper on the width...i might go otmorrow to bike shop and ask them....what do i say?do isay i cant skid or what??if i say i skid they'll say thats why its broken....?
So how'd it go Croat?
Shaun? ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
hey yeh didnt end up going,i looked at it and was just playing with the lever aand teh screws adjustign the pad and it seems i fixed it,either by chance or i knew what i was doing
thansk for askign anyways....
• Page 1 of 1
Return to Buying a bike / parts Who is onlineUsers browsing this forum: No registered users |
