Issue with new Garmin 500 GSC 10 speed sensor
Postby auswi2 » Sun Jan 29, 2012 5:13 pm
Gidday,
I purchased a Garmin edge 500 with the speed/cadence sensor on Australia day. I went out for my first outdoor ride today due to the rain in Brisbane and the Garmin picked up the speed/cadence sensor when I started the ride but my speed of the back wheel was all over the place showing 50kph when i was only doing 20 and it showed a max speed of 170kph (I Wish I was going that fast). I stopped and adjusted the spoke magnet and adjusted the arm so the gap was really close without touching but still the speed was not right. I have manually set the rear wheel circumference for a 700x23 2096 on the 500.
I cant find anything in Garmin support which tell me my unit is possible faulty or I have set something up wrong.
The cadence on the other hand was perfect so I moved the speed sensor arm away from the spoke sensor and restarted the edge 500 and done the rest of my ride using GPS for speed which seemed very accurate.
Any suggestions
auswi2
auswi2
by Forum Ads » Sun Jan 29, 2012 5:17 pm
Postby kb » Sun Jan 29, 2012 5:17 pm
Stupid question but you haven't changed from another speedo an accidentally ended up with two magnets?
kb
Re: Issue with new Garmin 500 GSC 10 speed sensor
Postby Le Velo » Sun Jan 29, 2012 5:32 pm
I know you said its new but my garmin tend to do that when the battery in the sensor is in need of being changed ....
Le Velo
Postby auswi2 » Sun Jan 29, 2012 5:43 pm
My old speedo had a front wheel sensor and the battery is fully charged in the head unit not sure how old the battery is in the GSC 10. Would a dead battery also affect the cadence which is fine.
thanks
auswi2
auswi2
Postby RonK » Sun Jan 29, 2012 5:53 pm
It's not at all uncommon, the Garmin forums have been full of complaints about flat batteries in GSC10 sensors since they were introduced with the Edge 305. Don't mess around, get a new one - CR2032 I think.
Postby auswi2 » Sun Jan 29, 2012 5:57 pm
I believe i have found the problem and it was from my end.
When I went out I did not turn the GPS off so I would have been receiving data from 2 sources. I spun the rear wheel on my trainer with the GPS turned off and it seemed accurate. is that correct that you need to turn the GPS off if using the Speed/Cadence sensor
auswi2
auswi2
Postby you cannot be sirrus » Sun Jan 29, 2012 6:09 pm
auswi2 wrote:I believe i have found the problem and it was from my end.
auswi2
No, I never turn my GPS off, try the battery as has been suggested as a first step.
Scott CR1
Postby auswi2 » Sun Jan 29, 2012 6:20 pm
Thanks I will
auswi2
Postby Comedian » Sun Jan 29, 2012 9:48 pm
If it's reading double then the magnet could be incorrectly aligned and the north and south pole is passing the sensor giving a double reading. I had this problem and turning the magnet 90Deg fixed the problem. :)
Those sensors are also really finicky to magnet alignment. Once they are set up they are all good though. :D
Comedian
Postby sumgy » Mon Jan 30, 2012 7:31 am
I am confused here.
Why would you turn off the GPS and use a magnet except for while you are on a wind trainer?
The GPS will tell you your speed at least as well as a magnet and you dont need to change your settings when you move the Garmin from bike to bike.
FWIW I dont think that your solution is the right one as I have had a magnet on my back wheel for some time (so that I have it there for when I am on the trainer) and never have the issue that you have raised.
Quality, not quantity.
sumgy
Postby Comedian » Mon Jan 30, 2012 9:10 am
sumgy wrote:I am confused here.
Gps don't do elevation well. Ie... When climbing or descending speed and distance will under read.
Garmin seem to use the sensor, gps, and barometer to sort it... Very clever.
Comedian
Postby mmhbeer » Mon Jan 30, 2012 12:09 pm
The Garmin 500 uses the wheel magnet to read your speed when you lose GPS reception eg in a tunnel, in a valley, under tree cover.
When you first go for a ride it picks up the magnet and then after about a km it calculates the wheel size for you.
I use a rear wheel speed sensor with my Garmin on my MTB. I had noticed that it would beep and auto pause when doing switch backs prior to fitting it, resulting in it reading rides a bit shorter than they are. All good with the magnet fitted.
mmhbeer
Postby auswi2 » Mon Jan 30, 2012 1:04 pm
If you have a cadence/speed sensor and have paired it with the head unit the Edge 500 will utilize the data from the sensor and the only time the GPS will calculate speed is if there is no speed/cadence sensor or the sensor arm is to far from the magnet.
thanks
auswi2
auswi2
Postby twizzle » Mon Jan 30, 2012 1:07 pm
auswi2 wrote:If you have a cadence/speed sensor and have paired it with the head unit the Edge 500 will utilize the data from the sensor and the only time the GPS will calculate speed is if there is no speed/cadence sensor or the sensor arm is to far from the magnet.
thanks
auswi2
No.
I ride, therefore I am.
twizzle
Postby auswi2 » Mon Jan 30, 2012 6:58 pm
When you say no which section are you saying no to.
This info has come direct from Garmin Support staff.
auswi2
auswi2
Postby hanzao » Mon Jan 30, 2012 7:32 pm
thanks
auswi2
Yes this is true
Cervelo 2012 R5 VWD SRAM Red
TimeTrials Felt B12
Northern Beaches Cycling Facebook
hanzao
Postby sumgy » Mon Jan 30, 2012 7:59 pm
mmhbeer wrote:The Garmin 500 uses the wheel magnet to read your speed when you lose GPS reception eg in a tunnel, in a valley, under tree cover.
Adjust auto pause to 0km/h.
Sorry, I still dont see the point of using a magnet when you have GPS.
Then again I dont seem to have had the issues others have had.
sumgy
Postby twizzle » Mon Jan 30, 2012 8:12 pm
auswi2 wrote:When you say no which section are you saying no to.
auswi2
And they are wrong in the way they have described it. The only time you are reliant on the speed sensor is if you disable GPS. Otherwise, it will use both sources and over-ride the wheel size to make the speed sensor match the GPS... unless you have set the wheel size manually, which is a daft thing to do.
twizzle
Postby twizzle » Mon Jan 30, 2012 8:14 pm
Both of mine died within weeks of each other, couldn't be arsed wasting more money on another one. The early units are very unreliable due to moisture ingress, the later ones are marginally better. There's a good write up on the net explaining how to rebuild them to be reliable.
twizzle
Postby mmhbeer » Mon Jan 30, 2012 9:12 pm
The problem is that when using gps it might take a reading say every 5 seconds. In that five seconds I might have done a switch back corner and then it takes it's reading again. This results in straight lining corners, giving oh a shorter riding distance.
It's not an issue on a roadie, only on the Mtb on twisty singletrack. If you export your data to google earth you can see the difference. You will see where the lines that it draws don't line up with the singletrack.
mmhbeer
Postby twizzle » Tue Jan 31, 2012 8:15 am
mmhbeer wrote:
sumgy wrote:Adjust auto pause to 0km/h.
Easily solved - If you use a power meter with the Edge500 it will record every second instead of using 'smart' recording. :P
twizzle
Postby casual_cyclist » Wed Jan 09, 2013 5:41 pm
Le Velo wrote:I know you said its new but my garmin tend to do that when the battery in the sensor is in need of being changed ....
I just had to replace the battery in mine and then re-pair. Seems to be working well after that.
casual_cyclist
Postby twizzle » Thu Jan 10, 2013 7:53 am
I had a look at my dead onces a couple of months ago. One was just having pairing issues, but the reed switch in the arm of the original one had failed. They don't have an infinite life, but it was probably only 18 months old when it carked it.
twizzle
Users browsing this forum: greatapoc, rangersac
