Best bike pump?
Best bike pump?
Postby ozzymac » Tue Feb 21, 2012 5:59 pm
Hi,
Just wondering if anyone can tell me the best bike pump to carry on the bike, one that will actually pump the tyre up?
Had my first puncture today, and the pump I had with me wasn't to crash hot.
Upon checking the pressure when I got home it only had about 50 psi in it, and even getting that in was a pain, and the pump fell apart....... At least it was enough to get home.
So any suggestions would be appreciated.
ozzymac
by Forum Ads » Tue Feb 21, 2012 6:17 pm
Re: Best bike pump?
Postby ozdavo » Tue Feb 21, 2012 6:17 pm
co2 - only use a pump on the road after running out of co2!
Get something LIKE THIS and some more OF THESE and your set :D
ozdavo
Re: Best bike pump?
Postby DaveOZ » Tue Feb 21, 2012 6:20 pm
I have one of these (actually 2, one on each bike) and it works well.
http://www.lezyne.com/hand-pumps#panel-2
DaveOZ
Re: Best bike pump?
Postby il padrone » Tue Feb 21, 2012 6:22 pm
The old Zefal HPX is out of production and virtually unavailable in bike shops, so my next-best pump of choice is the Lezyne Road Drive.
Best bike pump?
Postby ozzymac » Tue Feb 21, 2012 6:27 pm
That one looks like one of the old type hand pumps.
I actually have got a co2 thing on order, should turn up shortly.
But after the cheap pump gave up this morning, time for a new one I think.
Will check out the one recommended, thanks for the replies.
ozzymac
Re: Best bike pump?
Postby il padrone » Tue Feb 21, 2012 6:48 pm
CO2 is all fine and cool, but do bear in mind - it quite rapidly leaches through rubber tubes. Next day you'll need to pump up your tyre with real air.
Re: Best bike pump?
Postby Mulger bill » Tue Feb 21, 2012 7:17 pm
Lezyne. Whichever to suit your particular wheels. I've got one for the roadie/commuter and one for the MTB. The old skool hose attachment is gold.
Re: Best bike pump?
Postby fingy » Tue Feb 21, 2012 7:49 pm
This is what I am using, at 99mm it is small enough to fit in my small fizik seat bag with
a Co2 as my primary inflator. Used only as a backup I have used it many times without
fail, it can achieve 100psi but you would be there a while :). Once home a floor pump
is used.
Bigger hand pumps are much faster/easier but have to be frame mounted or carried
ok for the mountain bike, not the roadie but 8)
Manufacturers demo video below
fingy
Best bike pump?
Postby ozzymac » Tue Feb 21, 2012 7:59 pm
Is this one the same as the one recommended?
http://www.cellbikes.com.au/Lezyne-HP-Drive-Pump_251
It seems not a bad price if it is?
ozzymac
Re: Best bike pump?
Postby il padrone » Tue Feb 21, 2012 8:12 pm
ozzymac wrote:Is this one the same as the one recommended?
Certainly is a very good price. It looks to be a fair bit shorter than my Road Drive, so less air volume (slower speed of inflation).
"Oversized" and "120psi" are generally mutually-exclusive terms when it comes to pumps. You need a narrow barrel to be able to pump high pressures, unless you're built like Arnie. You can't get around physics :P
Re: Best bike pump?
Postby Mulger bill » Tue Feb 21, 2012 8:17 pm
Not the ones I've got (Road Drive and HP drive) but it states it is good for 120 psi. If so, the price is brilliant.
Re: Best bike pump?
Postby il padrone » Tue Feb 21, 2012 8:55 pm
Road Drive fitted.
Re: Best bike pump?
Postby __PG__ » Tue Feb 21, 2012 8:56 pm
I have a Zefal HPX.
1994 Cecil Walker custom steel frame with Shimano Ultegra STi
2013 Baum Corretto custom titanium frame with SRAM Force
__PG__
Re: Best bike pump?
Postby balap » Wed Feb 22, 2012 1:18 am
I have Giyo GM71.
http://www.ebay.com.au/itm/NEW-Giyo-Bik ... 27b953d083
It's an excellent pump for the price. Good quality product. Have no trouble getting to 120psi.
This is what I use at home. I carry CO2 cylinders on my bike.
balap
Re: Best bike pump?
Postby wardie » Wed Feb 22, 2012 7:18 am
I rode with a guy the other day who had a Crank Brothers pump - http://www.crankbrothers.com/pumps.php
A great piece of kit. Small enough to fit in your jersey pocket and has a High Volume/High Pressure switch.
Cervelo S2
wardie
Re: Best bike pump?
Postby Aushiker » Wed Feb 22, 2012 9:48 am
DaveOZ wrote:I have one of these (actually 2, one on each bike) and it works well.
Another vote for a Lezyne pump. Having the tube between the pump and the valve is a god send.
The downside with CO2 is the number of cylinders you have on board .... I have managed to puncture front and rear in one hit ...
Re: Best bike pump?
Postby MikeyD360 » Wed Feb 22, 2012 9:59 am
I have a small zefal and my first roadie puncture 60km from home was a nightmare - 30 mins of pumping and the tyre was still half flat, the end of the pump was too hot to hold and my arms and energy reserves were depleted.
I stopped at the next bike shop to borrow their track pump and rewarded their generosity by buying a CO2 kit and a handful of CO2 canisters.
I really wouldnt suggest a hand pump to anyone riding a roadie with high pressures unless you like being horribly inconvenienced at the worst times.
2012 Fuji SST1.0 stealth (full Ultegra)
2010 Merida TFS400D Hybrid
MikeyD360
Re: Best bike pump?
Postby il padrone » Wed Feb 22, 2012 10:18 am
MikeyD360 wrote:I have a small zefal and my first roadie puncture 60km from home was a nightmare - 30 mins of pumping and the tyre was still half flat, the end of the pump was too hot to hold and my arms and energy reserves were depleted.
It would be good to know exactly what Zefal pump this was. Certainly not the HPX as it will happily put up to 100psi and more in your tyres in under 5 mins. Zefal did do some larger barrel pumps and plastic pumps that were only suitable for MTBs with 50psi max tyre pressure.
Eg.
They also do the standard type of mini-pumps that are really inadequate for high pressure.
Best bike pump?
Postby ozzymac » Wed Feb 22, 2012 10:30 am
Thanks again for all the suggestions.
On the theme of best of ......
To go with the pump , what's the best all purpose tyre now a days?
Seems tyres that came with the Cannondale have had it. Schwalbe Ultimo. Did about 2400kms on them, is that about normal ? No punctures until yesterday due to tyre worn out.
ozzymac
Re: Best bike pump?
Postby MikeyD360 » Wed Feb 22, 2012 2:10 pm
It was this exact one -
MikeyD360
Re: Best bike pump?
Postby riddy » Sun Feb 26, 2012 10:11 am
Blackburn Airstik SL
59g, 160 PSI, <$20 online.
Nicely built. Fit to your bike and forget it is there. Has worked very well when I've needed it.
riddy
Re: Best bike pump?
Postby AlMac » Sun Feb 26, 2012 10:58 am
ozzymac wrote:Thanks again for all the suggestions.
Grippy, good lasting tyre, I would buy Continental, GP4000 (mine have lasted well), Gatorskin (for tough) or GP 4 Seasons (if you want the best of both worlds, for a bit more cash - GP4000 + tougher).
My mates tell me the Schwalbe doesn't last as well, but they make great tyres.
I've used cheap tyres once because they came stock on a bike I bought. Utter rubbish. I'd never waste money on cheap tyres again. Tyres are so key to ride quality, one of the best places to spend money.
AlMac
Re: Best bike pump?
Postby Ross » Sun Feb 26, 2012 1:38 pm
I have a Topeak Road Mprph and it will pumpthe tyre a genuine 120psi and you don't need to be Arnie to use it. There is a MTB version as well and also a Mini Morph which as the name suggests is a bit smaller but doesn't have the gauge like the Road Morph.
http://www.topeak.com/products/Pumps/RoadMorphG
Ross
Re: Best bike pump?
Postby simonr23 » Sun Feb 26, 2012 2:08 pm
ive a small hp drive (black and silver, 20cm long) that does both valve types with a double ended, detachable tube/nozzle. pumps my tyres up to about 110 easily and quickish, and if you have the strength will go to 120.
simonr23
Re: Best bike pump?
Postby Aushiker » Sun Feb 26, 2012 2:48 pm
Quite timely. BikeRumour have posted a review of a Lezyne Pressure Drive Mini. Might be worth a read.
Users browsing this forum: ansonvd, Google Adsense [Bot], linds
