Best strong Climbing wheelset at reasonable price
• Page 1 of 3 • 1, 2, 3
Best strong Climbing wheelset at reasonable priceI ride an oppy a5 with mavic aksium race wheels.
I do mostly climbing and these wheels flex a bit and it loosens the spokes quickly. Need advice on a wheelset that is, stiff, and reasonably priced. Cheers
Re: Best strong Climbing wheelset at reasonable priceDurace c24's rock.
Once you can climb hills on a bike it's all downhill.
Hopefully I'll know what that's like..... one day. ![]()
Re: Best strong Climbing wheelset at reasonable price2010 Oppy Pro
2013 Boardman CX Pro 2007 Giant TCR C0 2012 KHS Yuma 29er 2008 Kona Dawg
Re: Best strong Climbing wheelset at reasonable priceBeing a big guy myself, my answer would be to get the parts you want and get the wheels built by a good wheelbuilder. There are plenty of off the shelf options that can suit just fine though.
I'm going through the process of reading Jobst Brandt's book on wheelbuilding at the moment, and I would recommend that while you're waiting for the new wheels to get there, that you get the spokes tensioned a bit tighter. You may find that that will solve many of your problems. They will be a good training/backup wheelset then.
Best strong Climbing wheelset at reasonable priceI have of velocity deep v's from bicycle wheels.com cost about 370 inc postage.
Very stiff strong wheels.
Try Pro-lite Bracciano or Merano at our website: www.pro-liteoz.com Our Website is: http://www.pro-liteoz.com Find us on Facebook by searching for "Pro-Lite Australia"
Deep V's are not really lightweight climbing wheels. But they are strong.
Hope so because I got these too
Re: Best strong Climbing wheelset at reasonable priceMavic Ksyrium SL's for me. Hear good things about the Pro lites for the money.
Certified Brand Snob
Re: Best strong Climbing wheelset at reasonable priceFulcrum Zero or 1's - both excellent, bullet proof wheels with exceptional hubs and no weight limit.
S-Works Venge
Has anyone tried these ?
Re: Best strong Climbing wheelset at reasonable priceWhy not check out Melb Wheel builder Corecarbon? www.corecarbon.com.au they make a 38 and a 58 both are UCI legal and roll really nicely.
Re: Best strong Climbing wheelset at reasonable pricePretty light but there must be a reason similar "brand name" wheels cost 2 or 3 times that.
83kg limit might be the reason
Re: Best strong Climbing wheelset at reasonable priceHow much do you weigh?
Hmmmm...never heard of anyone who does mainly climbing before, on a roadie. Whatever your bodyweight, you'll get a stiffer wheel with a higher spoke count than the Aksium 20/20, and wider rear flange/flange width. Most OEM wheelsets have loctite or similar applied to the spoke thread, to stop them from loosening....quickly. But many wheelbuilders argue that loctite shouldn't be necessary if the wheels are tensioned correctly.
Take one Chinese wheelset Add two drops of decals Add 60% to the price tag Bake up a snazzy website and you have the same product as everybody else.
Re: Best strong Climbing wheelset at reasonable priceIf the original poster is lightweight you could build a set of custom wheels on Stans Alpha alloy rims which are less than 400 grams. Laced up to a set of White Industries hubs you'd have a sub 1400g wheelset that won't brake the bank. But this wouldn't be recommended for a heavier rider.
The newer Alpha rims are beefed up, so should be less of an issue weight wise.
I have! http://theclimbingcyclist.com/ 2010 BMC SLC01
Re: Best strong Climbing wheelset at reasonable priceIf I did a lot of climbing I·d be reticent to use carbon rims.
Agree. Braking on carbon rims on the way down is an issue. I wonder what the pros use on the big days in the Pyrenees and Alps?
very few (<10-15%) looked to be using carbon on the hills. most (>85%) did on the flatter stages.
If a large hub flange is high on your wish list - check these out: ![]() http://www.pro-liteoz.com/store/index.p ... oductId=83 Our Website is: http://www.pro-liteoz.com Find us on Facebook by searching for "Pro-Lite Australia"
Re: Best strong Climbing wheelset at reasonable priceFulcrum Zeros are plenty cheap on the interweb
S-Works Venge
Return to Buying a bike / parts Who is onlineUsers browsing this forum: No registered users |
