speedplay keep on kovers
Re: speedplay keep on kovers
Postby Dr_Mutley » Mon Jan 14, 2013 5:27 pm
twizzle wrote:Never had a problem with the springs, in fact on a couple of occasions I re-used the old springs so I didn't have to put up with the 'bedding in' time (they clip easier when the edges of the spring are rounded off).
Wear is quite a problem if u use zeros, and have them adjusted to allow no float. After 5000km or so the no float ends up sloppy, with a combination of both rotational float, and rocking (instability) due to wear of the spring. Not really much of an issue to those who run a fair degree off float however..,
Dr_Mutley
by BNA » Mon Jan 14, 2013 6:01 pm
Postby Baalzamon » Mon Jan 14, 2013 6:01 pm
When my new cleats arrive, I'm off to go get a bike fit done. I've got the fore/aft adapter kit which I'll have mounted already prior to going to the fit. I'll be going to see Damian Oldmeadow who I hope will take into account my metatarsal bursitis and move my cleats back away from forefeet area!
Baalzamon
Previous
Users browsing this forum: GNU
