twizzle wrote:Never had a problem with the springs, in fact on a couple of occasions I re-used the old springs so I didn't have to put up with the 'bedding in' time (they clip easier when the edges of the spring are rounded off).
Wear is quite a problem if u use zeros, and have them adjusted to allow no float. After 5000km or so the no float ends up sloppy, with a combination of both rotational float, and rocking (instability) due to wear of the spring. Not really much of an issue to those who run a fair degree off float however..,
