by NhiTrac » Tue Jul 24, 2012 8:54 pm
Hi all, So this evening I was forced to take a spoon of cement on the M5 with 25km to go, when my cable snapped forcing the rear derailleur into the lowest cog Anyway I made it home OK though with a higher average heart rate I'm going to replace all the inner cables as well as the outer sleeve as they haven't been replaced for about 7,000km+. Are there any specific brands that you guys swear by? I remember reading somewhere about sealed cables etc but cant recall the brand. Are these worth the extra $$$ or should I just pop over at the LBS and grab some OEM ones? Lastly, on average (taking into consideration time and distance), when should cables be replaced? Thanks in advance. Cheers
FOCUS Cayo Expert
NhiTrac
by Forum Ads » Tue Jul 24, 2012 9:09 pm
by Tornado » Tue Jul 24, 2012 9:09 pm
Can't help you with cables, but in future if you have a screw driver or anything that could be used as one you can lock your derailleur out in a better gear. Adjust the limit to whichever gear you prefer.
2012 Avanti Giro 3 2003 GT Palomar
Tornado
by NhiTrac » Tue Jul 24, 2012 9:18 pm
Tornado wrote:Can't help you with cables, but in future if you have a screw driver or anything that could be used as one you can lock your derailleur out in a better gear. Adjust the limit to whichever gear you prefer.
Thanks mate. I did not know this, will google it up. Have also added a multi-tool to my shopping list. Cheers
FOCUS Cayo Expert
NhiTrac
by }SkOrPn--7 » Tue Jul 24, 2012 9:28 pm
Commonly known as the "B screw" is what Tornado is referring too on your derailleur it force the jockey wheel to climb the cluster and just make small adjustments so the chain will stay on the cassette you choose.
}SkOrPn--7
by Aushiker » Tue Jul 24, 2012 10:57 pm
NhiTrac wrote:I remember reading somewhere about sealed cables etc but cant recall the brand. Are these worth the extra $$$ or should I just pop over at the LBS and grab some OEM ones?
I have recently fitted a set of Gore Ride On cables on my Surly Long Haul Trucker. Probably overkill for a touring bike but I am quite impressed with these cables. Nice and smooth operation. Regards Andrew
by Mulger bill » Tue Jul 24, 2012 11:57 pm
I use Jagwire all round with little drama but I'm thinking of a Gore kit for the commuter next time around. Typically, I go yearly, just after winter. It's pretty easy to check your cables every time you do the chain, an ounce of prevention etc.
by Cardy George » Wed Jul 25, 2012 8:49 am
Once upon a time there were Teflon coated cables, are they still available?
 Fondreist R10, Dura-Ace, Cosmic SL's Specialized Hardrock, Spinergy Xyclones And the occasional trailer full of kids......
Cardy George
by Strawburger » Wed Jul 25, 2012 9:34 am
Don't get cheap ones, they won't last the 7000kms you put in on the last set that's for sure!
I use the DuraAce in my road bike, i definitely can feel the difference to something that costs $5-$10. Haven't really experimented with others on the road bike but the other bikes usually get the cheaper stockpiled ones.
 n=8 (2011 road, 2004 road, 2010 track, 2009 foldup, 1990 hybrid, 1992 indoor trainer, 2007 road now a rental, 1970's step through)
Strawburger
by }SkOrPn--7 » Wed Jul 25, 2012 9:34 am
Cardy George wrote:Once upon a time there were Teflon coated cables, are they still available?
Yes I no longer worry about PTFE coated cables I buy a can CRC Dry Glide this allows you to coat the cables and spray the outer cables for a super slick operation. I also use this to coat parts that need lubricating but you want it to be dry so mud and road crud doesn't stick. Because it bonds to the material water doesn't effect it but just be careful how you apply it because it bonds so well if there is over spray you end up with some of your parts looking a shade of white so don't get near your paint work. It won't hurt your paint work but it bonds to it and hard to get off. Using Dry Glide you never have to worry about sticky cables but it cost 20 clams a can and last for ever. http://www.crcind.com.au/dry-glide-with-ptfeRicky
}SkOrPn--7
by Ozkaban » Wed Jul 25, 2012 9:52 am
I put gore low friction ones on my commuter when I built it. Not overly cheap (about $30 each for brakes and gears) but you can notice the difference. Happy to have spent the money.
Sent from my GT-I9300 using Tapatalk 2
Ozkaban
by __PG__ » Wed Jul 25, 2012 10:23 am
I'm getting Yokozuna cables for my next bike. Apparently they are the bees knees for SRAM.
SRAM now ship Red with Gore cables as standard BTW>
 1994 Cecil Walker custom steel frame with Shimano Ultegra STi 2013 Baum Corretto custom titanium frame with SRAM Force
__PG__
by NhiTrac » Wed Jul 25, 2012 11:29 am
__PG__ wrote:I'm getting Yokozuna cables for my next bike. Apparently they are the bees knees for SRAM.
You know, I was just about to ask you guys on your thoughts of these. I have them in my wiggle basket right now at $59. Hopefully they'll fit into my top tube's internal routing.
FOCUS Cayo Expert
NhiTrac
by __PG__ » Wed Jul 25, 2012 1:21 pm
Yes, they do warn that the cable housings are rather stiff. Here is what competitive cycles said about them
__PG__
by Cardy George » Wed Jul 25, 2012 6:24 pm
Right on cue! DaveOZ Cables topicThanks Dave!
Cardy George
by NhiTrac » Wed Jul 25, 2012 8:38 pm
That's sold it. Read a few other reviews and they all sound promising so have placed my order with some cutters Will update again once I've tested them out
FOCUS Cayo Expert
NhiTrac
by Dave R32 » Wed Aug 01, 2012 7:00 pm
Yokozuna are fantastic.
The brake outers have the same inner lining as the gear cables which makes for amazingly smooth feel. The only issue I found was the super stiff outers make routing these along your handlebars a bit more difficult than with normal cables.
Cheers Dave.
Dave R32
by SpinninWheels » Wed Aug 01, 2012 7:06 pm
NhiTrac wrote:So this evening I was forced to take a spoon of cement on the M5 with 25km to go, when my cable snapped forcing the rear derailleur into the lowest cog
I hope you kept it in the big ring!
SpinninWheels
by jacks1071 » Wed Aug 01, 2012 9:32 pm
NhiTrac wrote:Hi all,
Varies depending on usage and conditions. I change mine twice per year and I've never broken a cable, had pleanty of outer housings getting ready to fail after 6 months of usage. I always use the Dura-Ace outer which I buy in a 20 metre roll and for the inner anything reasonable quality.
jacks1071
by steve-waters » Fri Aug 03, 2012 2:00 pm
My outer will last forever but change my inners once or twice a year - same as Jacks near had one break.
Roadie: BeOne Black, SRAM Force, TWE 50mm full carbon clinchers, Vértebrae ceramic cable housings MTB: Chin29er, Fox Terralogic, XT, 3T and TWE wheels ex-MTB now commuter: Cannondale F900 (CAAD 4), Headshok, TWE wheels, XT and Elixr CR
steve-waters
by ldrcycles » Sun Nov 04, 2012 5:43 pm
I'm about to build a bike with internal cable routing and i've seen a few links saying the Yokozuna cables may or may not fit, does anyone have any first hand experience?
by NhiTrac » Sun Nov 04, 2012 8:20 pm
ldrcycles wrote:I'm about to build a bike with internal cable routing and i've seen a few links saying the Yokozuna cables may or may not fit, does anyone have any first hand experience?
Fitted Yokozunas to mine (internal rear brake) and they fit no problems. Ps they absolutely transformed the shifting and braking on my bike. Am loving them!
FOCUS Cayo Expert
NhiTrac
Users browsing this forum: Bing [Bot], Google [Bot]
