UDi2 vs DADi2 - any difference in fuctionality?
Postby Ross » Mon Aug 27, 2012 7:58 pm
I'm thinking of upgrading my 6700 mech group to UDi2. I've only ever test ridden DADi2, is there any differences in functionality between U and DA electronic groups?
Ross
by Forum Ads » Mon Aug 27, 2012 8:29 pm
Re: UDi2 vs DADi2 - any difference in fuctionality?
Postby jcjordan » Mon Aug 27, 2012 8:29 pm
The new UDi2 is a big improvement over the orginal Di2
- no need to heat seal connections
- Wiring kit is more adjustable
- ability to add more shifting points
Mind you they are not interchangeable in any way. The UDi2 will work with the new 9070 Di2
Sent from my Transformer Prime TF201 using Tapatalk 2
James
jcjordan
Postby chucknitro » Mon Aug 27, 2012 9:31 pm
New DADi2 coming December.
2013 Scott CR1 Premium - Ultegra Di2 compact.
chucknitro
Postby petal665 » Tue Aug 28, 2012 10:15 am
I have ridden both. While Ui2 has design advances, the servos in the FD and RD are 'off the shelf' and not custom made like the Di2, so are larger which makes it ugly. Despite what one reviewer said, the front shifting on Ui2 is waaay slower (well somewhat slower) than Di2. The new DADi2 will have the same design advances as Ui2 and then some and will be the bizz, but it will also be expensive. Ui2 is half the price of Di2 and is the better value.
petal665
Postby HAKS » Tue Aug 28, 2012 7:55 pm
Get along to the Giant demo day at Stromlo in late Sep and try out Ui2 yourself on the crit track for a good 45min. That's my plan anyway ;). Pitty they won't have any of the new DA 9070 stuff there though :(
Check the ACT thread for details.
Current Ride: Giant 2010 TCR Advanced 1
HAKS
Postby ratter » Tue Aug 28, 2012 8:39 pm
a little off topic but along the same theme:
has anyone made sprint shifters for the Ultegra Di2?
ratter
Postby petal665 » Tue Aug 28, 2012 9:01 pm
ratter wrote:a little off topic but along the same theme:
You can't, not easily like with DA Di2
petal665
Postby ratter » Tue Aug 28, 2012 9:05 pm
Why?
I was under the impression that the shifters have the required spare port and at the momment a remote style shifter was available.
Not being funny, I don't own the system as yet but it what i want to run on my new build.
ratter
Postby petal665 » Tue Aug 28, 2012 9:09 pm
ratter wrote:Why?
DA Di2 is a simple momentary switch, Ui2 is not.
petal665
Postby ratter » Tue Aug 28, 2012 9:21 pm
heres a link to the satellite shifter
http://www.roadbikeaction.com/fly.aspx? ... 9&cid=5088
ratter
Postby petal665 » Tue Aug 28, 2012 9:31 pm
ratter wrote:heres a link to the satellite shifter
I know what they are but you can't just make them like you can with Di2. DA Di2 send s simple pulse down a dedicated wire from each button to the brains. Ui2 sends a different signal type from each button down a wire to the brains. Without knowing the signal type required for each button, and having a method of making it, you can't simply make extra buttons.
petal665
Postby ratter » Tue Aug 28, 2012 9:46 pm
thanks for the answers, but do you realise the link was for a satellite shifter for Ultegra Di2 not Dura ace? not trying to be argumentative, but believe if they can make a satellite shifter work then they should be able to get sprint shifters working, happy to be corrected
ratter
Postby bosvit » Tue Aug 28, 2012 10:34 pm
From your link I think this line pretty much sums it up
"The satellite shifters first saw use with the sprinters in the ProTour and will soon come to Ultegra."
bosvit
Postby Crawf » Wed Aug 29, 2012 8:39 am
You could use the SW-R600 as spint shifter but it would look pretty bulky and be uncomfortable when sprinting in the drops.
Crawf
Postby petal665 » Wed Aug 29, 2012 9:06 am
ratter wrote:thanks for the answers, but do you realise the link was for a satellite shifter for Ultegra Di2 not Dura ace? not trying to be argumentative, but believe if they can make a satellite shifter work then they should be able to get sprint shifters working, happy to be corrected
You original question came across as asking has anyone in the cycling community hacked together some sprint shifters, the answer is no and it isn't easy. Will Shimano do it? Yes they will, once the new DA Di2 comes out the accessories will (should be anyway) be compatible with Ui2.
petal665
Postby ratter » Wed Aug 29, 2012 11:00 am
I know it got off topic but thanks for all the answers.
I was not after a hacked version of the sprint shifters or using the satellite shifter as sprint shifters, just wanted to know if anyone had seen any aftermarket companies listing sprint shifters for it.
ratter
Postby dude18 » Mon Oct 01, 2012 5:51 pm
The new di2 (both UDi2 & DADi2 9070) have chips in the system that use CAN bus protocol. That's how the shifter buttons can be reprogrammed to move any derailleur in any direction, and how the computer connection kit can detect point to faults at exactly which components are faulty.
dude18
Users browsing this forum: Bing [Bot], mitzikatzi
