Triple: http://www.bike24.com/1.php?content=8;n ... pgc=69:235
Search for trials cranks:
http://www.onza.com/components/drivetra ... nkset.html
http://www.tartybikes.co.uk/cranksets/o ... 10079.html
24T is a common trials size. With a (common) 20T sprocket that would be basically the same ratio as 26-22.
You will probably lose your chain guard. If you want to keep it, you could cut your existing chainring and adapt a custom ring onto the 3 holes for that small ring.
