Cheap ANT+ computer
Re: Cheap ANT+ computer
Postby clackers » Wed Jan 30, 2013 9:46 pm
I've got a Bryton 50 and a 35. I think they're works in progress versus the established Garmins, but with big improvements in the last year. One thing they've got going for them is battery life.
clackers
by Forum Ads » Mon Feb 04, 2013 7:50 pm
Postby Dadrock » Mon Feb 04, 2013 7:50 pm
not directly on point, but if you're after a new mobile you could do what I did and get a Sony Ericsson Xperia Active. it has an ANT+ sensor built in. I downloaded the Garmin app, got a cadence/speed sensor for the bike and I'm away. Will also pick up a HR monitor when I get serious.
phone is pretty waterproof. I mounted it with a Quad Lock universal mount, with the BNA discount! :D
martin
"You make pigs smoke. You feed beef burgers to swans. You have big sheds, but nobody's allowed in..."
Dadrock
Postby clackers » Tue Feb 05, 2013 9:03 pm
Dadrock wrote:not directly on point, but if you're after a new mobile you could do what I did and get a Sony Ericsson Xperia Active. it has an ANT+ sensor built in. I downloaded the Garmin app, got a cadence/speed sensor for the bike and I'm away. Will also pick up a HR monitor when I get serious.m
Can't imagine what the battery life will be like, Martin, with the screen on full time, with GPS and ANT+ (effectively Bluetooth) as well.
Still, it should be okay for shorter rides.
clackers
Postby Dadrock » Thu Feb 07, 2013 11:19 am
I have the screen on low brightness, no bluetooth, but yeah, it can chew through a battery. I've only done a couple of 2-3 hours rides and it makes it through okay, but then I don't really use the maps finction much as I know where I'm going.
It's the speed and cadence info I like, and the ability to download the ride to Garmin Connect, and then across to Strava to see if I've improved on a couple of particlar segments.
It is a bit of a novelty, but I was never going to get a Garmin (the expenditure would be approved by Treasury), and I needed a new phone after my 7 year Nokia finally died.
Martin
Dadrock
Postby clackers » Thu Feb 07, 2013 10:25 pm
Dadrock wrote: (the expenditure would be approved by Treasury)
We share your pain, Martin! :smile:
clackers
Previous
