Best 29er Fork in QR
Postby the-waves » Tue Oct 16, 2012 12:36 am
Hi all,
I have been riding my Karate Monkey y rigid for some time and am getting tired of the sore neck & wrists that go with riding a rigid setup.
Time for some suspension forks.
I am leaning towards a pair of Fox Racing Shox 2012 32 'Float 29' 80 RLC 29er Forks but would welcome all input if I am way of the mark.
the-waves
by Forum Ads » Tue Oct 16, 2012 7:21 am
Re: Best 29er Fork in QR
Postby Jean » Tue Oct 16, 2012 7:21 am
If you are willing to pay the $$ then the Fox will probably be hard to beat overall. If you want to save some dollars you could check out lots of forks. The X-Fusion 26" forks have got pretty good reviews, so their 29" forks might be worth a look. I've got some Suntour Epicon 29er forks which I've yet to ride much, but they seem pretty good bang for buck. Lots of options for QR 29" forks.
Jean
Postby schwing » Tue Oct 16, 2012 7:32 am
Have used and can recommend Rockshox Rebas -
If youare aheavy rider 100kg plug the bigger FOX numbers may be worth a look but dont think they are available in QR
schwing
Postby silentbutdeadly » Tue Oct 16, 2012 8:59 am
If the KM fork is the stock steelie then I'd also consider a carbon rigid rather than a slushie fork. Less weight than either the steel fork or a slushie so better handling & less work, some can be had that are quite compliant plus they are often cheaper than a slushie to buy and definitely cheaper to maintain...have a yarn to Larry at Larry's Custom Cycles - he's a rigid rider, bike customiser and a White Bros agent and might be able to offer you some options in either suspension or rigid carbon...
silentbutdeadly
Postby maybolem » Wed Oct 17, 2012 9:13 am
Either Fox, or DT Swiss has been making extremely good forks in the last 1-2 years, and 2013 will be sixk, and a few of the top mtb riders in the world race with DT Swiss.
maybolem
Postby the-waves » Fri Jan 04, 2013 6:06 pm
Thanks for the input guys, ended up going with FOX FLOAT 32 29ER FORK 1 1/8 NON TAPERED 9MM QUICK RELEASE, will let you know how I get on!
the-waves
Users browsing this forum: Bing [Bot], reefer
