Rebuilding my wheel
• Page 1 of 1
Rebuilding my wheelA few months ago my ultegra rear hub cracked.
I've now decided to rebuild the wheel since the rim is still good... I've got to choose between buying a Ultrgra hub brand new or a Dura ace 7700 hub off eBay
Re: Rebuilding my wheelSave yourself some cash and pick up some 105 hubs which are almost identical to ultegra hubs.
Just make sure that when you get them you check the grease levels and properly adjust the cones and they will roll as sweet as! You can buy a pair from Ribble for just over $60.
Re: Rebuilding my wheelAre all the Shimano hub measurements you mentioned identical or within 1mm? Other wise you'll be forking out for new length spokes too.
Re: Rebuilding my wheelwell id be lacing it with new spokes, far as I've been told 105 hubs are no where near the quality.. and as I've stated in my post I do not wish to downgrade to 105 hub since id be replacing a ultegra
The hubs from ebay are these http://www.ebay.com.au/itm/180993597615 ... 1436.l2649
Re: Rebuilding my wheelThere is indeed an increase in quality as you go from 105 to Ultegra then Dura-Ace. But its a small one. 105 hubs are very good, roll smoothly, and are very robust. Ultegra, etc, are marginally better - but you are paying a lot more for a small increase.
If you want Ultegra, then go for it. But don't fall into the "105 is no good" trap. I use a mix of 105, Ultegra and Dura-Ace gear on my bike, and interchange it reasonably often - and so long as its well-maintained, I honestly can't tell when I have 105 vs Ultegra vs Dura-Ace stuff on... Cheers, Abby My blog: http://cgradecyclist.blogspot.com/
If you look at the tech diagrams the difference between 105 and Ultegra hubs is the axle and the QR skewer, otherwise they are identical. I doubt you could tell the difference, in fact a low grease badly adjusted Ultegra hub will perform and feel 10x worse that a well greased properly adjusted 105 hub.
Re: Rebuilding my wheelHas anyone had much experience with these hubs?
http://www.ebay.com.au/itm/Circus-Monke ... 56464ba27a they seem to get a decent rep from the roadbike review forum
Re: Rebuilding my wheelIMO shimano hubs a very similar, except for the entry level 2200 and sora ones which I could never get super smooth. Ultegra hubs are going to weigh less than 105 but if you can find the time to maintain them they will perform just as well, I'm willing to say that the Tiagra hubs will be just as smooth as the Ultegra hubs if well maintained (the hubs in my R-500 wheelset are brilliant, I assume they are Tiagra).
Can't comment about the Circus Monkey hubs as I have never used them, but there are plenty of cheap "weight weenie" hubs out there, see Bikehubstore Can you imagine what I would do if I could do all I can? - Sun Tzu
___________________________ Giant Defy Advanced 0 Shogun Katana
Re: Rebuilding my wheelWell I've looked into buying hubs from bhs and sapim cx-ray spokes which total out at $298
SL218 Rear Hub - 218 grams UltraLight Front Road Hub - 32h - 80g Sapim CX-Ray Teamed up with the Open Pro's, I should be looking at around 1450g for the set. So in the end it should cost me $298 + $130 in labour to re-build both wheels, or should I go for a Pro-lite set? bearing in mind that I'm still around 98kg
Re: Rebuilding my wheelBuild it up yourself... $130 for a rebuild is ridiculous.
The Pro-Lite Merano should be fine for you. You're very close to our recommended max weight for the Bracciano. If its just a training wheelset, the Como I would recommend without hesitation - they are strong, despite being heavy they roll very well and have good aero characterics. Our Website is: http://www.pro-liteoz.com Find us on Facebook by searching for "Pro-Lite Australia"
read sheldon brown's guide... great source of info Can you imagine what I would do if I could do all I can? - Sun Tzu
Re: Rebuilding my wheelHow does one go about getting the right measurements for the spokes required for my rebuild on both wheels?
Rims: Mavic Open Pro's Hubs: http://www.bikehubstore.com/product-p/ul80.htm http://www.bikehubstore.com/SL218-p/sl218.htm Spokes: Sapim CX Ray I tried using the calculator but couldn't track down all the info required :S some help would be nice
Re: Rebuilding my wheelFind all of the required measurements and enter them into a calculator. You will need your ERD (effective rim diameter, usually found on the Manufacturer website, BUT ITS BEST TO MEASURE IT YOURSELF)the hub Flange (how far away the spokes are from the centre) diameter, also found on the manufacturer website, or the website of the store selling them and the flange spacings (how far the flanges are from the centre), again available off the websites. Bikehubstore will give you a good response if you ask them, I've just come back from a hard ride so not the most capable at the moment
Re: Rebuilding my wheelThe BikeHubStore site has the hub measurements
Front - PCD 39.6mm, center to flange (equal) 33.5mm Rear - PCD DS 49.6mm NDS 38mm, center to flange DS 17.1mm NDS 37.3 Mavic Open Pro ERD is 602mm, but you may want to measure this yourself. These are all the numbers you need to plug into a spoke calculator. You just need to decide on what cross, for 32H I'm guessing you would want 3x.
Re: Rebuilding my wheelI'll be going to the lbs and see how the guy wants to build it
Thanks for the help guys
Might I suggest you check out the price of getting your wheels built at starbike in Germany. From memory its 24.50 Euro for the build and postage is appeared to be 20 Euro last I looked which is cheap as chips if its correct. They were as cheap as anyone else appeared for their sapim cx-rays. Where they fall down is their speed as the German mail takes on average about a month at least to get to you. If you prefer speed, I bought my last wheels with cx-rays from wheelbuilder.com of whom I dealt with "Joe Wiley: Wheelbuilder.com" <[email protected]> Their prices are on their website but if your spokes are a standard length and dont need custom shortening (like mine did) then they are US $3.15 each for cx-rays. I used Velocity rims which were $65 each and supplied my own hubs. Hope some of that helps Moulton Landrover APB
Good prices too Moulton Landrover APB
Re: Rebuilding my wheelThe rim I already have as it was only the hub that was cooked not the rim
Thus is why it's getting built locally
• Page 1 of 1
Return to Buying a bike / parts Who is onlineUsers browsing this forum: Bing [Bot], chriscole, Google Adsense [Bot], SG89 |
