Which tail light is this?
Postby Stuey » Thu Oct 25, 2012 6:56 pm
Hi people,
I'm trying to find out which tail light I've been seeing lately, as it's excellent and I want one. This light is a simple single extremely bright LED that has a slow strobe cycle of about once per second (on for a second, off for a second). This is the best tail light I've seen (as a driver from behind). The lens or reflector makes it look like a simple 10mm or so spot, and can be seen for hundreds of metres. No other LED's present.
I find tail lights that flash rapidly actually make some people try not to look (me being one of them) as it can trigger migraine - not a good outcome for a safety lamp!
Any ideas? I've seen a few lately, but haven't been able to ask.
Stuey
Stuey
by BNA » Thu Oct 25, 2012 7:01 pm
Re: Which tail light is this?
Postby Baalzamon » Thu Oct 25, 2012 7:01 pm
Radbot 1000?
Baalzamon
Postby sunho » Thu Oct 25, 2012 7:22 pm
If it is the radbot, cell bikes normally have specials here and there and you can pick it up for 16 bucks
Sent from my Nexus 7 using Tapatalk 2
sunho
Postby Riggsbie » Thu Oct 25, 2012 9:07 pm
I have 2 RadBots and they look just like that !
Riggsbie
Postby Stuey » Thu Oct 25, 2012 9:16 pm
I thought it might be the Radbot, but wasn't sure.
Stuey
Postby sunho » Thu Oct 25, 2012 9:42 pm
Some YouTube videos have the flash comparisons. Have a geez!
sunho
Postby Magnum9 » Thu Oct 25, 2012 10:30 pm
Check out the niteflux redzone 4, much better visibility than any of the narrow optic style spot rear lights.
Magnum9
Postby Stuey » Thu Oct 25, 2012 10:32 pm
Hmm. Not sure. I saw some Radbot vids and none seem to be just a plain onnnnnn... offfffffff.... onnnnnnn.... offfffffff (no pulsing or fading in/out).
Stuey
Postby Baalzamon » Fri Oct 26, 2012 12:03 am
Dinnote possibly then?
Baalzamon
Postby sunho » Fri Oct 26, 2012 1:17 am
Or nite stinger or lezyne exposure flare...
sunho
Postby ningnangnong » Fri Oct 26, 2012 7:56 am
You might be thinking of the Cygolite Hotshot.
I've got one and it's a beast!
ningnangnong
Postby humanbeing » Fri Oct 26, 2012 7:58 am
Radbot has 3 settings:
Slow pulse, quick flash and constant on.
I'm very happy with mine, I use it in quick flash mode.
I found out about the Radbot when I was following a cyclist on my commute and was very impressed with their rear light. When I caught them at the traffic lights I asked what light it was and promptly got one myself.
Paired with a Superflash on my helmet I think I'm well lit from the rear :lol:
Peter
2012 Jim Bundy
1995 Bosevski - Athena
mid/late eighties Colnago Cromor
humanbeing
Postby tallywhacker » Fri Oct 26, 2012 2:00 pm
Stuey wrote:Hi people,
Stuey
with that sort of flash pattern I doubt its the Radbot (I've had several, still got the dead boddies). Could be the cygolite hotshot which has an adjustable flash pattern and duration.
Ever since the vasectomy...I mostly ride fixed.
tallywhacker
Postby Riggsbie » Fri Oct 26, 2012 4:01 pm
Dinotte lights are awesome too, I have a 400R (I think) and it is sooooo bright, but they are expensive but I figure safety and being seen is important !
Riggsbie
Postby il padrone » Fri Oct 26, 2012 4:46 pm
NiteFlux Red Zone 4 is a pretty damn stunning tail light. Aussie-made too, just a shame there is no bolt-mount to fasten it to a pannier rack :(
Postby Mulger bill » Fri Oct 26, 2012 10:27 pm
il padrone wrote:NiteFlux Red Zone 4 is a pretty damn stunning tail light. Aussie-made too, just a shame there is no bolt-mount to fasten it to a pannier rack :(
Yeah, great light Pete but I'm not fond of the mount either. I MagGyvered a bit of sheetmetal into a bolt on tongue that works perfectly on a standard Superflash bracket for better fit with the available space on the seatpost of my commuter. I reckon I could manage something if you came up with dimensions and pics of what's needed.
Shaun
Postby fingy » Fri Oct 26, 2012 11:29 pm
might be this one
fingy
Postby NhiTrac » Sat Oct 27, 2012 10:21 am
+100 for this little retina burner. Have been running mine for a couple of months now. Solid bright unit.
I too, wish it had a proper mount system to make de/attaching a bit easier
FOCUS Cayo Expert
NhiTrac
Postby NhiTrac » Sat Oct 27, 2012 10:23 am
Shaun[/quote]
Care for a quick pic pls?
FOCUS Cayo Expert
NhiTrac
Postby Stuey » Sat Oct 27, 2012 12:25 pm
Thanks Guys. You're not gonna believe this. I had a migraine yesterday from a previous evening looking at lights on You Tube. Some of us sufferers get one from certain flashing lights. Arrggh! :oops:
I did spend some extended time looking at my Italian superflash copy to see how visible it was...dumb move.
Stuey
Postby Stuey » Sat Oct 27, 2012 12:33 pm
Didn't look for too long :roll: , but yes, I think it's the Cygolite (slow flashing isn't an issue, it's the strobe).
Stuey
Postby Mulger bill » Sun Oct 28, 2012 8:53 pm
NhiTrac wrote:
Shaun
Sure thing, here yer go. I must've deleted the MSPCAD file but I found a hard copy in the shed and scanned it. :?
The drawing doesn't show (or allow for) the dogleg needed in the adaptor shown in the side view-because I forgot about it right up to first test fit :oops: The hole for the latch took some work with rattails after falling off a 4mm drill bit. A cold chisel and hammer was used to put a small lip into the lower edge of the latch hole. It's worked a treat so far.
Users browsing this forum: Google [Bot], jd73, Pedaling
