Help me find a good pump...
• Page 2 of 2 • 1, 2
Re: Help me find a good pump...To repeat what I said above - for high pressure look for a skinny pump. This Giyo is much better for $25 -http://www.ebay.com.au/itm/GIYO-160psi-Road-Pump-With-Puncture-Repair-Kit-/150921875283?pt=AU_Sport_Cycling_Accessories&hash=item2323a50f53
Thanks... because if I really get into this bike riding thing
If you are budget conscious the GIYO Micro Floor Pump TDC mentioned early is a good deal. They can be found online for under $20.
Re: Help me find a good pump...I bought this a few weeks ago:
http://www.chainreactioncycles.com/Models.aspx?ModelID=42197 And it is pretty good, better than my $40 Leyzene.
It's average - just like every one I've ever chucked. Just for clarity: I'm not harping on about the (admittedly more expensive) Lezyne out of snobbery. It's just that I really do believe that it is a demonstrably better item. The way I approach these things is thus: If I am hemming and hawing over something, I compare the price of it to a tank of petrol. If it costs more than a tank of petrol, it's worth deliberating over. If it costs the same as a tank of gas or less, I just buy the darn' thing and move on. My bike blog. Long on rumination, rambling and opinion. Why let facts ruin everything?
You intend to spend up to $2000 on your bike but you can't justify $80 to keep the tyres inflated That seems like a false economy to my way of thinking. Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
OP said that $50 - $80 on a pump cant be justified right now. That is the bottom line to this discussion. He does not want to spend 80 bucks... The $20 pump uses the the same air as the $80 pump, and he can buy 4 of them over the next 25 years. Either way his tyres will get air in them and he can ride his bike to the coffee shop where he can get ridiculed for having the wrong pump.
You either misread or are splitting hairs dear sir. Read again what I wrote
Re: Help me find a good pump...OK, seems I did misread you . Sorry
But as I said, don't be wary of buying quality, and I'm talking about functional quality, not poseur value. My Lezyne Micro Floor Drive just works, and works very well Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
Ta, I know all about quality, dont worry. But I also dont want to spend big now and then later on not use it. I will keep an eye on for the Lezyne if I can find one on-sale, but probably will settle for a lower end one (but not too low, some of the ones I tried were just junk).
Re: Help me find a good pump...The problem with buying a low quality pump is that it will probably last quite a while as you put up with crumby performance. This really matters if you have a family and you need to pump up six or ten tyres.
I still have my Silca Pista exactly like this: http://thefridaycyclotouriste.com/?p=4773 which I have had for nearly 30 years. I used to think it was an excellent pump until I got a Lezyne. Who would have thought that a simple tube with a plunger and a hose could be so nicely engineered? Now I understand how lousy the Silca is - the rubber seal on the valve fitting is very primitive and the handle is very hard on the hands, the shape is wrong and too small. I now have a Lezyne Alloy Dirt Drive, an Alloy Floor Drive an HP Road drive plus a HV Road Drive. My Silca has become a museum piece.
Re: Help me find a good pump...With the Lezyne Micro Floor Drive HV, I have always found it rather tricky to connect the chuck's threaded end to the base for stowing.
![]() Then just on the weekend a mate pointed out the bleeding obvious - hook up the threaded chuck first..... ![]() ....then stretch the rubber hose over the handle There is a right way to use the handle as well when pumping, to avoid the edges of the groove for the hose biting into your hand. Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
I've had this $10 pump for 7+ yearsWhilst a big fan of Lezyne (a couple of my friends have bought the fantastic Lezyne Super Drive XL front light on my recommendation) I've been perfectly happy with this ~$10 BBB mini frame pump.
So happy in fact that after having one on my roadie for years I bought another one for my MTB four years ago. Both still going strong. And should I ever lose, break, or have one stolen I'll simply get another. I don't understand why anyone who buys a $2000 bike thinks they need a frame pump that costs almost $100. If you ride your bike 10 hours a week then over four years the bike costs you ~$1 per hour and the pump costs you ~$100 per hour. Where's the sense in that? byke.com.au - Find the cheapest cycling gear from your favourite stores
Re: I've had this $10 pump for 7+ years
I'm guessing you don't subscribe to house or car insurance ?? Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
Same cause of failure as mine If I actually added up the cost of my pumps and divided by the number of flats, I'm sure the bottom line would be rather nasty but the ultra slim chance of being let down by these pumps makes them worthwhile for me. ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
Well that's a strange assumption to make. (And whilst I'm unable to see the relevance, it's also incorrect.) I'm not suggesting don't buy a pump. Far from it. I'm simply suggesting that you can buy a perfectly functional mini pump for about $10. It's lightweight, easy to use, and mine has given me at least seven years of reliable service. (Which means it has probably had about an hour's active use in its lifetime). byke.com.au - Find the cheapest cycling gear from your favourite stores
Re: Help me find a good pump...The air wont be of the same quality from your $10 pump...The bike wont feel as good
Return to Buying a bike / parts Who is onlineUsers browsing this forum: Baalzamon, Google [Bot], TheWoodenTree, Walastik |
