Bontrager Race Wheels
Postby HoldYaLine » Thu Jan 03, 2013 8:46 pm
Hey guys, my LBS offered me $4600 for a trek madone 5.9 2013, which is about $400 off. It comes with Bontrager Race Lite Wheels. SPECS:
MSRP $700
1,500 grams/pair
23mm wide OSB alloy rims (622x17)
Nail head spokes and stacked drive-side lacing
Bontrager designed, sealed cartridge bearing hubs with 3-pawl drive mechanism
18 front and 24 rear 14/15g bladed spokes with Alpina locking alloy nipples
Includes Bontrager internal-cam skewers, TLR rim strips and TLR valve cores
Compatible with both Shimano and SRAM 9/10 spd and Shimano 11spd cassettes
Campy compatible with free hub part number 420390
Compatible with both traditional, TLR and road tubeless clincher tires
No rider weight restrictions
So, i was researching these wheels, and many say to try and upgrade to these, The bontrager Race X Lite Wheels. SPECS
MSRP $1,000
1,480 grams/pair
Locally reinforced spoke nodes reduce rim weight without sacrificing strength
Bontrager designed hubs with DT 240 star ratchet internals, nail head spokes and stacked drive-side lacing
18 front and 24 rear DT 14/17g bladed spokes with Alpina locking alloy nipples
Campy compatible with free hub part number 276362
So..... My LBS said, hed give me the bike with the better wheels for $4800 Still, it is 200 dollars off a bike, and getting a 300 dollar ("Better") wheelset.
Do any of you think i should consider spending the extra money???? i have no experience with wheels whatsoever, just from what i gather, its better to have parts made by a company rather than just stock standard stuff i. DT SWISS, the Race X Lites are really tempting with the DT240 Hubs....
HoldYaLine
by BNA » Thu Jan 03, 2013 9:22 pm
Re: Bontrager Race Wheels
Postby jcjordan » Thu Jan 03, 2013 9:22 pm
A friend of mine has a set and they are a great wheeled. Quite stiff and light but definitely a race day rather then a everyday wheel.
DT Hubs are some of the best on the market.
James
jcjordan
Postby HoldYaLine » Fri Jan 04, 2013 10:46 am
thanks
HoldYaLine
Postby biker jk » Fri Jan 04, 2013 5:48 pm
There's not much of a weight difference for the price difference and the cheaper wheels will be sturdier due to the wider diameter spokes. I personally would go for the cheaper wheels which should prove more durable, especially if you're a heavier rider. In any case, the 23mm wide rims are great. I built a set and found they corner better and you can run lower pressures (by 10psi) which produces a more comfortable ride.
biker jk
Return to Trek
