by takai » Mon Jan 07, 2013 10:19 am
Any thoughts on diagnosing this one: clicking coming from the crank area on my 08 Giant TCR C2. Generally when drive pedal is between 12 and 2, although sometimes happens at other points in the stroke. Doesn't happen at big power stuff. Mainly when I'm spinning along at 100rpm or so. Happens in all gears on both chain rings. Oh and I've just changed the bottom bracket, and chain/rear mech and cluster is 750km old.
Thoughts?
takai
by Forum Ads » Mon Jan 07, 2013 10:23 am
by cyclotaur » Mon Jan 07, 2013 10:23 am
Cleats..... or dicky knees  .... yeah, possibly cleats/pedals somewhere.
cyclotaur
by Mulger bill » Mon Jan 07, 2013 11:43 am
takai wrote:Oh and I've just changed the bottom bracket, and chain/rear mech and cluster is 750km old.
Thoughts?
Dirty/dry threads in the BB shell? Dry spindle before the left crank was installed? Left crank not fully torqued during install? There's probably 997 other possible reasons...
by bychosis » Mon Jan 07, 2013 11:54 am
Just coz it sounds like that's where it's coming from doesn't mean that's it. Could be seat post, stem. Process of elimination will get thee. Remove, replace, lubricate one thing at a time until it goes away.
bychosis ( bahy-koh-sis): A mental disorder characterised by symptoms, such as delusions or hallucinations, that indicate impaired contact with reality not containing bicycles.
by Mulger bill » Mon Jan 07, 2013 11:58 am
bychosis wrote:Just coz it sounds like that's where it's coming from doesn't mean that's it. Could be seat post, stem. Process of elimination will get thee. Remove, replace, lubricate one thing at a time until it goes away.
Down to 995  Loose QR skewers makes for 994... The blue bit is vital when hunting rogue clicks.
by Uncle Just » Mon Jan 07, 2013 11:59 am
Four more of the 997.... rh crank hitting derailleur cable or end cap on every rotation; pedal bearings loose; rh crank hitting derailleur cage; chain ring bolts loose. I've also read that sometimes on carbon frames a noise thought to be in BB area can be in the seat post zone because sound travels and gets amplified. So check seat clamp and seat post bolts. If threads are dry lightly grease.
Uncle Just
by twizzle » Mon Jan 07, 2013 12:06 pm
My most annoying click turned out to be a seat post. Took aaaaages to identify. But given it started after the OP played with the BB... probably a good place to start.
I ride, therefore I am. ...real cyclists don't have squeaky chains...
twizzle
by lambretta » Tue Jan 08, 2013 2:57 pm
Just spent a few days chasing one - it turned out to be the extra length of cable on the front derailleur tapping on the frame.
lambretta
by takai » Sun Jan 13, 2013 6:41 pm
Just did a full grease and rebuild on the bike. Regreased and torqued the cranks, BB cups, pedal threads, seatpost, headset, and bidon cages, retightened the cluster and the QRs (which are new). Found that the headset bearings were a bit loose, but the LBS says that they are all kind of like that when not compressed in situ. Its this type of bearing:  Hopefully the noise is gone, if not i cant think of many other places to look. Cant see any obvious cracks in the frame either.
takai
by Dave R32 » Mon Jan 14, 2013 11:18 am
Check the rear derailleur hanger and main mounting bolt for tightness along with the chain ring bolts. I have had clicking from these areas on more than one bike.
Cheers Dave.
Dave R32
by TDC » Mon Jan 14, 2013 12:42 pm
TDC
by takai » Mon Jan 14, 2013 5:52 pm
Well I think I have found the clicking noise. 99.9999% sure it was the rear bottle cage, has a crack in the mount and I noticed it shifting back and forward while cycling today.
Popped the new bottle cages on this afternoon, and voila no clicking noise.
takai
by __PG__ » Mon Jan 14, 2013 6:37 pm
 1994 Cecil Walker custom steel frame with Shimano Ultegra STi 2013 Baum Corretto custom titanium frame with SRAM Force
__PG__
by NhiTrac » Mon Jan 14, 2013 8:26 pm
Mine was a warn chain.
FOCUS Cayo Expert
NhiTrac
