Does anyone know if a Gates belt drive setup can be used to drive the Shimano Alfine 700 or the Rohloff 14 speed?
Gates belt drive - ShimanoSG-700Alfine compatibility?
• Page 1 of 1
Gates belt drive - ShimanoSG-700Alfine compatibility?Does anyone know if a Gates belt drive setup can be used to drive the Shimano Alfine 700 or the Rohloff 14 speed?
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?Some discussion from the Thorn Forum about this, and more specifically a response from a manufacturer. It seems that with a Rohloff, to retain their very valuable worldwide warranty, you'd need the conversion to be done by Rohloff and using a frame that would meet their specs for rigidity.
Probably cheaper and easier to get a bike that is already designed for it. There are such, but most are sold out of Europe and will cost $$$$. Tout Terrain Silk Road <too big image removed> Retrofitting to the Alfine 11 I know little about, but it may be an easier task Last edited by il padrone on Fri Jan 25, 2013 1:10 pm, edited 1 time in total.
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?I have an Avanti Inc 3 which has an Alfine 11 speed hub and Gates CDX belt drive
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?Thanks for the tips. Great places to start.
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?Fitting a belt drive to an Alfine 8 or 11 is reported to be fairly straight forward.
A Di2 (electronic shifting) Alfine is much more problematic, although apparently it is possible, at least if you have access to a machine shop. I was going to buy a fast, stylish bike, but I looked in the mirror & thought "you're not fooling anyone, you know"
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?Agree with il padrone, working with a frame designed for a carbon drive will save time and money.
BNA Feature: E-Bike Buyers Guide App on Now iTunes
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?Hi polydexta,
This company seems to have some clues on installation. http://www.stkildacycles.com.au/gates-belt-drive- http://www.stkildacycles.com.au/rohloff
Yes straight fit, 3 spline, fits on as you would with a normal chained sprocket.
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?St Kilda Cycles built my touring bike up with a Rohloff and Gates Belt Drive. It's a modified Charge Duster. I love it. I'd get the Center Trak if I were doing it again, but the extra 2mm width of the belt might cause problems on a modified frame.
http://www.crazyguyonabike.com/doc/page ... 85919&v=LC
• Page 1 of 1
Return to Buying a bike / parts Who is onlineUsers browsing this forum: Google [Bot] |
