Ultegra Brake and Cable Replace/Install
Postby lb121 » Fri Feb 01, 2013 8:44 am
Hi All,
Need to purchase and have installed a new set of Brake and Gear cables for my Giant TCR Advanced which is running full Ultegra.
Unfortunately my preferred LBS(Stanmore Cycles) has closed down and I'm now forced to look elsewhere to have my servicing needs met. I visited another LBS who quoted me $240 to purchase and install the cables which I feel is a bit excessive considering I can purchase the cables locally for $80 all up.
What are your thoughts on this price?
What would your LBS charge?
Can you suggest an LBS around the inner west?
Regards,
Lachlan
lb121
by Forum Ads » Fri Feb 01, 2013 9:02 am
Re: Ultegra Brake and Cable Replace/Install
Postby macca33 » Fri Feb 01, 2013 9:02 am
Honestly, if you are baulking at the cost, then it may be best that you learn to perform the replacement yourself (plenty of instructional manuals / videos on the net)- it is not overly difficult if you take your time and measure twice - cut once.
As for the LBS quote, there would be at least a couple of hours in doing the changeover - bar tapes, etc, etc; so that and the addition of new cables, tuning the bike, etc would mean that $240 is not overly excessive.
'dale CAAD10 - Ultegra6700 | Giant Defy 1 - DA7800
macca33
Postby rkelsen » Fri Feb 01, 2013 9:06 am
$80 for brake cables? I hope you're not serious?
I'm still using some that I purchased for $4 each back in 2009.
Look on Ebay, buy the cheapest you can find and install them yourself. It's an easy job.
$240 is sheer lunacy.
volutamus scandemus
rkelsen
Postby ball bearing » Fri Feb 01, 2013 9:13 am
Get yourself some quality cable cutters:
http://www.ebay.com.au/itm/Park-Tool-CN ... 460c12e778
Changing the cables is routine maintenance and very easy.
ball bearing
Postby Saturnstarzz » Fri Feb 01, 2013 10:31 am
Ball bearings right but this will help you if you want to have a crack yourself. Torque wrench might be handy to have .
http://techdocs.shimano.com/media/techd ... 605105.pdf
2009 Cannondale CAAD9-5,
Single speed GT Avalanche 2.0
Saturnstarzz
Postby lb121 » Fri Feb 01, 2013 11:51 am
Think I will end up doing it myself it will be a good learning experience. I've been told the latest version of ultegra requires a special gear and brake cable due to the under bar integrated brifters having higher friction which is why the cables are so expensive.
lb121
Postby TDC » Fri Feb 01, 2013 12:59 pm
lb121 wrote:Think I will end up doing it myself it will be a good learning experience. I've been told the latest version of ultegra requires a special gear and brake cable due to the under bar integrated brifters having higher friction which is why the cables are so expensive.
Bollocks. Cables have been routed under bar tape for years without the need for space age cables. I relalced the FD cable on Ultegra 6700 with a standard 1.2 mm gear cable and the performance was the same as before.
TDC
Postby biker jk » Fri Feb 01, 2013 1:07 pm
I have one Ultegra bike which uses the PTFE coated Shimano cables. On the other Ultegra bike I used Jagwire cables. There is NO difference in shifting between the two bikes. One piece of advice is to make sure that you don't have too tight a bend in the gear cable outers routed under the bar tape. You have the option of routing behind or in front of the bar so choose the route which produced the smaller bend.
biker jk
Postby lb121 » Fri Feb 01, 2013 2:30 pm
TDC wrote:Bollocks. Cables have been routed under bar tape for years without the need for space age cables. I relalced the FD cable on Ultegra 6700 with a standard 1.2 mm gear cable and the performance was the same as before.
Thank you for this confirmation the LBS I visited today insisted that I must use the PTFE cables sets otherwise shifting and braking will suffer, will be ordering some jagwire and doing myself over the weekend.
lb121
Postby outnabike » Fri Feb 01, 2013 4:25 pm
Hi lb121,
This mob has some cheap stuff that may suite you.
http://cyclingdeal.rtrk.com.au/?scid=14 ... 2262021944
outnabike
Postby lb121 » Sat Apr 13, 2013 1:42 pm
Thanks for the replies everyone much appreciated.
lb121
Postby __PG__ » Tue Apr 16, 2013 10:34 am
Pedro's cable cutters are also recommended.
1994 Cecil Walker custom steel frame with Shimano Ultegra STi
2013 Baum Corretto custom titanium frame with SRAM Force
__PG__
Return to Shimano
