Thoughts on DA 9000 C50 clinchers vs comparable wheelsets?
• Page 1 of 1
Thoughts on DA 9000 C50 clinchers vs comparable wheelsets?I note Merlin cycles have a great price on the new DA 9000 C50 clincher (gee that's a mouthful) and wondered if there any opinions on how good a deal it is compared to similar wheelsets, both for rim depth/shape and weight? After paying GST I think they should come in at A$1375 delivered. Hit me with your thoughts?
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetI am 90kg so no lightweight and I mainly ride criteriums and moderate climbs. I subscribe to the aero is better than weight argument.
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetpfft 90kg. skinny bugger.
Litespeed Tuscany with SRAM Force and Open Pros - soon!
I am a lighweight I know ![]()
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetobviously not enough hills around your area
Or I don't tackle them often enough ![]()
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetMerlin put their price up on the C50 clinchers so I am back to the drawing board. Cycling Express have them but you can't add them to your basket for some reason
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetI have a set of C50. and a set of the RS80's as well. The C50's are faster on the flats but the RS80 i find climb better. I wouldn't of beleived it till riding on the RS80 for a while and then stick the C50's on for a long ride.
Out to highfields i find the C50's get going better. MDL
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetThanks Matt. Are the RS 80s lighter or just feel lighter climb on?
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetThey are lighter,
MDL
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetHmmm, lighter might also mean more prone to me busting something. I think I will pull the trigger on the C50s.
Get a power meter and ride up grades instead of buying 'upgrades' that really make no difference at the end of the day. Its mostly just marketing hype. I worked in the industry. Ive never had a drivers license. I will bang out the same wattage up Norton Summit with the latest DA wheels as a 100$ pair of shimanos. Maybe 4-5 seconds quicker over 15minutes. Srsly, get a power meter and you will understand what the fuss is about. Vegan since 2001...
Re: Thoughts on DA 9000 C50 clinchers vs comparable wheelsetYou can get the RS80 (Ultegra) C50's for $700 from Planet X bikes. Meant to be same wheel, different hub. Might be worth checking out.
• Page 1 of 1
Return to Buying a bike / parts Who is onlineUsers browsing this forum: Bing [Bot], Google Adsense [Bot], LinzOC, reeves |
