Sold wrong inner tube ?
deagles
Postby deagles » Fri May 23, 2008 6:50 pm
I'm back on 2 wheels for the first time in about 20 years - and a few things appear to have changed - so I need some help please !!
I've got a flat on my hybrid. The tyre size printed is 700x35 - and I have been sold a tube that has a box marked as "700x18/23 40" (price tag says 700x19C 40mm).
Gut feel is it's too small. Can some please confirm if I've been sold the wrong size tube ?
MountGower
Postby MountGower » Fri May 23, 2008 7:07 pm
G'day deagles
You can go a little too small but I wouldn't go that far. If it said 28/32, I'd use it, but I think that is definately too small. I can't see you having a problem exchanging it, regardless of who's error it is.
vitualis
Postby vitualis » Fri May 23, 2008 9:54 pm
Yes, the tube is too small.
700x18/23 40 I would assume mean a tube that will fit a tyre that is 700C 18-23 mm width with a 40 mm length valve. The price tag: 700Cx19C 40 mm basically states the same thing (but saying that it will fit a 700C 19mm width tyre... which is within the range).
Regards.
Michael Tam
Photos: Michael's bicycle obsession
2009 Pegoretti Responsorium Ciavete Custom :: 1982/3 Colnago Super :: 2006 Cannondale Six13 Pro :: Late 1980s Repco Superlite
deagles
Postby deagles » Sat May 24, 2008 3:07 pm
Thanks to both of you for confirming my suspicions and thanks to vitualis for deciphering the last part of the numbers. I returned it today for the correct size.
alchemist
Postby alchemist » Sat May 24, 2008 4:20 pm
700x19 is small, but will work fine. I end up using these in my 'cross bike running 35mm tyres most of the time as it saves me having to remember to have spares of different size of tubes. I do find them a little more prone to pinch flats, but no difference in punctures.
Users browsing this forum: uart
