Need a single
mikesbytes
Need a single
Postby mikesbytes » Thu Jun 27, 2013 4:06 pm
I'm looking at buying a disc wheel that I'll use for both Road TT and Track.
As it will have dual purpose, I need to select a tubular tyre that is suitable for both situations. I'm assuming that I should go 22 or 23mm but which one I don't have experience with
The wheel will not be used for training and to my knowledge the roads where TT's are conducted are fairly clean.
Strawburger
Re: Need a single
Postby Strawburger » Thu Jun 27, 2013 8:20 pm
You will also need a tub that doesn't have a specific direction of travel if its the disc I'm thinking of. It's a flip flop track/road disc?
n=10 (2013 & 2004 roads,2010 track,2x 2009 foldups,1990 hybrid,1992 trainer,2007 rental,1970's step through,1980's zeus)
mikesbytes
Re: Need a single
Postby mikesbytes » Thu Jun 27, 2013 10:48 pm
Strawburger wrote:You will also need a tub that doesn't have a specific direction of travel if its the disc I'm thinking of. It's a flip flop track/road disc?
Good point, I need to wait till the wheel turns up so I can determine if the conversion is a flip/flop or ends up being the same direction.
Also I need to decide on which glue, so any suggestions on that?
jacks1071
Re: Need a single
Postby jacks1071 » Thu Jun 27, 2013 11:14 pm
Zipp Tangente would be my recommendation, very fast tyres and not directional.
http://www.zipp.com/accessories/detail.php?ID=51
Ross
Re: Need a single
Postby Ross » Fri Jun 28, 2013 11:53 am
Don't forget to get a valve adaptor
http://www.wiggle.co.uk/zipp-disc-wheel ... p-adapter/
I use Vittoria Triathlon Evo Tubular Tyre on my disc wheel because it is one of the few tubulars that has a rubber inner tube (as opposed to latex) so it will stay pumped up. Pumping up a disc wheel is very hard (impossible?) by yourself and it's one less thing you have to worry about on race day.
http://www.wiggle.co.uk/vittoria-triath ... ular-tyre/
I use Continental glue (there is a different version for carbon and alloy wheels). Need about 3/4 of a tube per tyre
http://www.wiggle.co.uk/continental-tub ... ment-glue/
dalai47
Re: Need a single
Postby dalai47 » Fri Jun 28, 2013 2:48 pm
I currently use a Vittoria Evo CX 23mm on the disc wheel I use on both concrete and timber tracks. Naturally not quite as fast as the Vittoria Pista EVO on timber, but still a low rolling resistance tyre and wears well.
I also use the EVO CX for TT's and RR's too...
