2012 Avid BB7 Mechanical Disc Brake Set - eBay
Postby Aushiker » Fri Jul 19, 2013 12:14 pm
Hi
I am looking at switching over to Avid BB7 mechanical disc brakes on my mountain bike which I use for loaded touring. Anyway poking around eBay and there is a Chinese seller, jfstore1 selling a front and rear set of http://www.ebay.com.au/itm/2012-Bicycle-Avid-BB7-Mechanical-Disc-Brake-Set-Front-and-Rear-160mm-G3-Rotors-/110972729217?pt=AU_Sport_Cycling_Parts&hash=item19d67d7781&_uhb=1 brakes for a pretty good price ...
A price which is too good to believe? Am I missing something here or are they worth a shot?
~ Aushiker.com
Re: 2012 Avid BB7 Mechanical Disc Brake Set - eBay
Postby Mulger bill » Fri Jul 19, 2013 1:15 pm
Sounds like a great deal on great kit Andrew.
Too great? Maybe. He has a good score but what's the guts of his feedback profile like?
Shaun
ozdavo
Postby ozdavo » Fri Jul 19, 2013 1:18 pm
I purchased an AVID HS1 rotor from a chinese seller and it is definitely a knock off. Can't say what these will be. I have just mounted it to the rear of my recently built hardtail, so will see how it performs.
Any reason you want cable over hydro? Is it a touring/maintenance thing?
Nobody
Postby Nobody » Fri Jul 19, 2013 1:21 pm
Something you should know is that BB7s are supposed to be matched with G2 rotors, not G3.
Crawf
Postby Crawf » Fri Jul 19, 2013 3:29 pm
Am expecting a fork from the same seller any day now. Has some good prices.
jenysmith
Postby jenysmith » Fri Jul 19, 2013 3:33 pm
I have a set of BR-M495 calipers on order from an eBay sale. They were so cheap that they were practically free($15!). I already have levers for them. I will update you when I get them set up. They will be nothing compared to my kick ass hydraulic four piston M755's, but for the cost, I will not complain.
Postby Aushiker » Fri Jul 19, 2013 3:52 pm
ozdavo wrote:Any reason you want cable over hydro? Is it a touring/maintenance thing?
Touring/maintenance thing :)
~ Aushiker.com
Postby Aushiker » Fri Jul 19, 2013 3:55 pm
Nobody wrote:Something you should know is that BB7s are supposed to be matched with G2 rotors, not G3.
Thanks. Missed that.
~ Aushiker.com
seanneko
Postby seanneko » Mon Jul 22, 2013 10:40 am
The rotors are quite likely fakes (the ones that fibica sells are), but I don't think fake BB7 calipers exist. So they should still be good.
That said, I've used both fake HS1 rotors and genuine HS1 rotors and noticed very little difference between them.
Postby Aushiker » Mon Jul 22, 2013 2:46 pm
I think I will just cough up and get the genuine product ... after all this is playing with brakes and really probably not something to play with.
~ Aushiker.com
cobba
Postby cobba » Sun Jul 28, 2013 11:54 am
The G3 was never supplied by Avid with the BB7's and the larger braking track on the G2 rotor matches the BB7 pads better then the smaller braking track on some rotors like the G3 and HS1 but Avid is now supplying the HS1 rotors with the BB7 Road SL, BB7 Road S and BB7 Mountain S.
http://www.sram.com/avid/component/mechanical-disc-brakes
Different pads and rotor combinations on the BB7's seem to have different recommended usage.
BB7 Mountain S comes with Organic pads and HS1 rotors.
Intended Use: Cross Country, Trekking, Comfort, Mountain.
http://www.sram.com/avid/products/bb7-mtn-s-mechanical-disc-brake
BB7 Mountain comes with Sintered pads and G2 rotors.
Intended Use: XC / TRAIL / AM / FR / DH
http://www.sram.com/avid/products/bb7-mountain-mechanical-disc-brake
rifraf
Postby rifraf » Mon Jul 29, 2013 11:05 am
Not sure if its still relevant as prices tend to fluctuate, but when I was looking for my Ogre, then bike24 was the go
http://www.bike24.com/p29971.html
49.99 Eu
Edit.
Just spotted a sale on Jensons prices of $54.00
http://www.jensonusa.com/Avid-BB7-Mecha ... e-180mm-11
cobba
Postby cobba » Mon Jul 29, 2013 11:41 am
If you want 160mm rotors then you can get front and rear for $77
http://www.ebay.com.au/itm/New-Avid-BB7-Disc-Brake-Calipers-G2-rotors-Front-Rear-/220776074605?pt=AU_Sport_Cycling_Parts&hash=item3367478d6d
2012 BB7's are the same as the 2011 model, the 2010 model, the 2009 model and and 2008 model.
rjk
Postby rjk » Mon Jul 29, 2013 1:11 pm
if it is on ebay and they accept paypal you are covered, if they just accept a direct deposit be very very careful
Boardman CX pro now the commuter, Salsa Casseroll, Trek Domane
Users browsing this forum: Yahoo [Bot]
