Does this Rear Wheel exist?
Vaderico
Postby Vaderico » Thu Nov 07, 2013 9:46 pm
I'm looking for a very specific wheel.
I ride a Singlespeed / Fixie at the moment and am looking to upgrade it to a 5 speed internal gear hub.
However there is a specific criteria I am after;
There are three things I am looking for, but am unsure where to start looking:
1 - Have a disc brake on the hub
2 - Be a deep dish style rim, sized 700c
3 - Coloured Black
I am not too fussed which make of internal geared hub to buy, whichever one fits the criteria I am willing to buy.
Also If a hub can meet these requirements that has a slightly different amount of gears, then I wouldn't mind too much
If someone has the experience / knowledge to lend me a hand, I would be forever grateful.
richbee
Re: Does this Rear Wheel exist?
Postby richbee » Fri Nov 08, 2013 8:54 am
SRAM have an i-3 internal geared disc hub you could get built into a wheel of your specification. 'tis only a 3 speed hub tho.
MattyK
Postby MattyK » Fri Nov 08, 2013 10:10 am
Sturmey Archer is about the only maker of 5-speeds, and I don't know if they do disc mount.
Shimano if you can handle 8 or 11.
SRAM for 8 or 9.
Rolhoff if you need 14.
But most of the latter will be wider OLD spacing than an existing singlespeed wheel. No biggie if you have a steel frame, it can be reset.
I reckon you'll be up for a custom build if you want deep dish AND hub gear, but this is about the cheapest complete wheel I know of:
http://www.bike24.com/1.php?content=8;n ... duct=62210
Not deep though.
Gordonhooker
Postby Gordonhooker » Fri Nov 08, 2013 11:08 am
Shimano Alfine 8 speed is the closest you'll find I think and it comes in black, but you would have the get the wheel built up from scratch. Not sure how readily available the spokes would be though.
http://www.bicyclestore.com.au/shimano- ... d-hub.html
OI onya bike!!!
Postby find_bruce » Fri Nov 08, 2013 1:08 pm
One possible issue with a deep dish and an alfine 8 is that due to the pitch circle diameter of the hub (92.6 mm) you end up with a significant angle at the rim, or more accurately the angle between the spoke and the nipple. I was having issues with a shallow rim Mavic A719. The way I addressed it was using sapim spokes with polyax nipples
A deep dish will only make the angle worse. I haven't built wheels with a deep dish so couldn't say whether the polyax nipples would still avoid any issues.
Postby find_bruce » Fri Nov 08, 2013 1:18 pm
MattyK wrote:Sturmey Archer is about the only maker of 5-speeds, and I don't know if they do disc mount.
Sturmey Archer 5 speeds with a disc brake come in 4 flavours - high flange, low flange, & repeat with a 9 spline driver. All have a 135 mm old though
Calvin27
Postby Calvin27 » Fri Nov 08, 2013 2:24 pm
Nexus 7/8 (if you can find them) or Alfine 8 are your best bet. You can get the alfine in a wheel package so all you do is put it on and attach the cables.
*Edit: forgot about the dish. You should be able to get custom spokes but I would have to know that the wheel builder is very experienced.
Fast light bike
Cushy dirt bike
Workhorse bike
No brakes bike
Ebike :)
Postby Duck! » Fri Nov 08, 2013 9:50 pm
This is a deep dish wheel:
Just saying.....
Users browsing this forum: adam0bmx0, LabsRock61a, Thoglette, vinski
