Gear & Brake Cables
RRalphy
Gear & Brake Cables
Postby RRalphy » Fri Nov 08, 2013 11:20 am
Hi
Doing my first build (yay? :( ) and wanted to check what I needed in terms of cables. I will be running a mix of sram red and force on the bike and wanted opinions on what cables to get and to check that I needed inners and outers, do they come as a set?
Also on a side note the brakes I am going to order are sram force 22 dual pivot brakes, this wont be an issue for me running a 10spd groupset right since it is just the brakes??
thanks
jaseyjase
Re: Gear & Brake Cables
Postby jaseyjase » Fri Nov 08, 2013 3:11 pm
You can buy cables as you need, ie
complete set - bout outters, both inners, ferules, cable ends for both gears and brakes.
brake or gear set - the above but for either gears or brakes only
seperately - outters, inners etc
just read the descriptions when purchasing, and make sure its the right compatibility, ie campy or shimano/sram.
as for brakes, i dont see it being a problem.
biker jk
Postby biker jk » Fri Nov 08, 2013 3:42 pm
Postby Mulger bill » Fri Nov 08, 2013 8:37 pm
Good gear, used on much of my bikes.
I would suggest Goodridge are better, if slightly pricer. IIRC, about $30 for each (shift or brake) kit from CRC last time I did the commuters cables. Should get another pair for the spares box...
Postby Duck! » Fri Nov 08, 2013 9:56 pm
I find the Shimano sets to be mighty good. Make sure you get PTFE-coated inner gear cables though; it's needed to counteract the friction of the hidden routing. Jagwire & SRAM cable coating tends to fray & jam up the outers, but I've never had that issue with Shimano.
As far as compatibility goes, Shimano & SRAM are fully compatible, Campag will accept other brake cables, but has specific gear cables.
Dave R32
Postby Dave R32 » Sat Nov 09, 2013 12:40 pm
Genuine SRAM gear inner cables are 1.1mm diameter and easier to thread through the levers than Shimano or other brands of inner cables which are 1.2mm. I would recommend you get a set of Yokozuna Reaction cables and use SRAM inners on the gears.
Dave.
Avanti Vivace = Sold | Trek Madone = Cracked | '12 Caad10 = Sold | Pinarello SDG3K | '14 Caad10 & Bianchi Pista
Users browsing this forum: Shred11
