Frame mounted pumps
Cmm
Frame mounted pumps
Postby Cmm » Mon Nov 11, 2013 1:13 pm
Hi in the market for a new mini pump and am trying to decide weather to go with a regular mini pump with a hose or going one of the frame mounted mini floor pumps.
What are you guys and gals using and what's your recommendations?
I have been looking at the lyzene range.
I am a cyclist who just goes on day trips no extreme ks and no touring if this changes anything.
Cmm
jacks1071
Re: Frame mounted pumps
Postby jacks1071 » Mon Nov 11, 2013 1:34 pm
Definitely one with a flex hose.
ShogunHy
Postby ShogunHy » Mon Nov 11, 2013 1:50 pm
Got a THIS small frame mounted thing but haven't had to use it yet - ok for emergencies though wouldn't like to use it all the time..
Just bought a Speciaized Air Tool Pro floor pump which is pretty amazing.... pretty indestructible though not something you can easily carry around - more for pre-ride pressure checking..
as with a lot of accessories price is a good indicator...
Shogun Metro SE Flat Bar Hybrid - Circa late 90's
Specialized Sirrus Comp - 2011
simonn
Postby simonn » Mon Nov 11, 2013 2:04 pm
Depends on the sort of riding.
For fast training rides/racing, mini pump (with hose) in jersey pocket. If I get a flat I'm not going to be riding that far, will probably not catch up the group anyway so it is just to get me home.
For audax, where I might be riding a few hundred km after fixing a flat, I have a frame mounted mini floor pump with a gauge - can't remember which one, but it was a cheap one I bought from T7 (I think) which I have seen under several cheapo brands. Like the Topeak <something>-morph pumps, but with a metal foot thingy rather than plastic.
For commuting, a mini floor pump lives in my messenger bag - serfas and a bit bigger than the one on my audax bike, but no gauge. Have got > 140psi out of it (accidentally, no gauge).
FWIW, frame mounted mini floor pumps can be difficult to mount on modern road bikes because of the (stupid) frame shapes (whats wrong with round!).
EDIT: Always have a hose or you will eventually break a valve.
jacks1071
Postby jacks1071 » Mon Nov 11, 2013 5:14 pm
ShogunHy wrote:Got a THIS small frame mounted thing but haven't had to use it yet - ok for emergencies though wouldn't like to use it all the time..
Hand pumps without a flex hose are without exception, rubbish. Far too easy to snap the valve off your tube with this type.
Cmm
Postby Cmm » Mon Nov 11, 2013 6:03 pm
Thanks I think the lyzene mini pump is looking good.
ShogunHy
Postby ShogunHy » Mon Nov 11, 2013 9:56 pm
Yeah kinda thought as much per the price comment ...
Postby il padrone » Mon Nov 11, 2013 10:15 pm
Unless it's the Zefal HPX - best pump on the road, but only a frame-fit job. No longer made, sadly.
Check out the Lezyne Micro Floor-drive - great pump in stand-pump format, with a hose and pressure gauge.
HappyHumber
Postby HappyHumber » Mon Nov 11, 2013 10:42 pm
+1 to all previous hose comments.
Lezyne do make some great products.
Might need to be mindful of some tubes having removable valve cores as well, with the Lezyne "ABS" threaded hose-to-valve attachment system. Not a show stopper, but it kinda sucks to have just got a road tube up to pressure, only to pull the valve out straight off with the hose head. More just to be a quirk to be wary of......... No need to ask me how I know :oops:
- Kym
Postby RonK » Mon Nov 11, 2013 11:03 pm
Cmm wrote:Thanks I think the lyzene mini pump is looking good.
What's with this lyzene? Is it some cheap chinese rip-off copy?
HappyHumber
Postby HappyHumber » Mon Nov 11, 2013 11:09 pm
RonK wrote:What's with this lyzene? Is it some cheap chinese rip-off copy?
I was trying to find the "p!ssing by a window" sketch, in a bit more brevity... but you can have this one anyway;
- Kym
Cmm
Postby Cmm » Tue Nov 12, 2013 5:30 am
Thanks for the heads up happyhumber
jacks1071
Postby jacks1071 » Tue Nov 12, 2013 2:17 pm
il padrone wrote:Unless it's the Zefal HPX - best pump on the road, but only a frame-fit job. No longer made, sadly.
That is pretty cool. I don't think I'd hang one from my bike as it'd be rubbing on my calves where the photo shows it being mounted but I do like it :-)
A mate of mine had an old school pump the entire length of the top tube (mounted under the top tube) - now that was a good pump. I can't remember how he had it mounted, was on an old steel frame but it always worked a treat. High pressure and fast.
TDC
Postby TDC » Tue Nov 12, 2013 2:56 pm
Thats the zefal HPX type pump (or at least its less evolved ancestors) mentioned earlier. We all had them back in the bad old days. That's all you could get.
I had one like exactly like this.
http://www.zefal.com/en/traditional-pum ... ev-88.html
ha ha..Evans still have them in stock.
Users browsing this forum: Cosh, DarrylH, jarwil80
