Creating compact set-up
- nirismo
Postby nirismo » Mon May 05, 2014 8:07 pm
Every time after work I drive past a local bike shop which Giant bikes (thinking about getting one, lol) and decided to pop in to see what they have. So anyways, they had the TCR Advanced 3 (2012) in red which looked pretty sweet. Was hoping they had one in white. The thing is that is doesn't have a compact set-up 50/34 which I really dig! It currently has a 39x52T on the crank and a 12-25T on the cassette. Is there a way to make it so that it close to a compact set-up? Not just for this bike but other bikes aswell. Cheers.
Note: I'm not very knowledgeable in this.
Nirismo.
Re: Creating compact set-up
Postby Stuey » Mon May 05, 2014 8:42 pm
Postby Baalzamon » Mon May 05, 2014 9:21 pm
Postby macca33 » Mon May 05, 2014 10:03 pm
- Rockford
Postby Rockford » Mon May 05, 2014 10:10 pm
- open roader
Postby open roader » Mon May 05, 2014 10:27 pm
+1Stuey wrote:Some people request a compact crank at the time of purchase and bike shops will usually accommodate them.
When i purchased my TCR Adv I told my LBS I'd only buy it if they could supply compact cranks and 11-28 cassette - I asked and I received.
You are the customer, go get yourself the deal you want.
- Xplora
Postby Xplora » Tue May 06, 2014 10:48 am
Trek doesn't sell any bikes with a standard crank - most people want a compact these days, especially if they are near hills. Also worth considering that if it DOES come with a standard crank, the likelihood is that the geometry and ride feel could be much more aggressive than you really want. Standard crank means sprinting for crits. Super fast, super short rides. I wouldn't bother putting different cassettes on the standard crank to make it easier to turn. Better to have a compact with a tight cassette, than a standard with a wide one.
Postby ab012 » Tue May 06, 2014 1:05 pm
- nirismo
Postby nirismo » Tue May 06, 2014 2:26 pm
open roader wrote: +1
Looks like I'll definitely be doing this. With a 50/34 on the front is a 11-28 ideal? Or should I go with something else? They're asking $1,999 for it incl $300 of anything (which I don't need). I'll see if they can do $1,699 with Compact 50/34 and 11-28 cassette. If not I'll move on.Xplora wrote:If they can't swap the crank, consider a different bike at the shop, or a different shop.
- Xplora
Postby Xplora » Thu May 08, 2014 12:11 am
- kb
Postby kb » Thu May 08, 2014 7:00 am
Triple? I know it's decidedly unfashionable...Xplora wrote:... and mark my words, comfort on the big climbs can't come with comfort on the flats
- barefoot
Postby barefoot » Thu May 08, 2014 9:10 am
Also requires [1] a new shifter, so the double-to-triple upgrade gets quite spendy.kb wrote:Triple? I know it's decidedly unfashionable...Xplora wrote:... and mark my words, comfort on the big climbs can't come with comfort on the flats
But if the option is there... I fully endorse the motion that they are decidedly unfashionable. Triple cranks give the best of all worlds. A nice tight cassette, nice overlap between the rings so you're not forever front-shifting like you are on a compact, and nice low winching gears for the odd occasion when you need them.
As for the OPs question - the smallest inner ring you can fit on a "standard" bolt pattern is a 38T - only just. 39T is more common. If you want a smaller ring, you need a smaller bolt circle... which means different crank arms. Either with a "compact" bolt pattern (110mm bolt circle diameter instead of 130mm on standard, which will fit down to a 34T ring), or with a second smaller bolt circle for a granny ring on a triple (standard road triples have 130mm and 74mm bolt circles, which can fit rings down to a 26T IIRC although 30T is more usual).
tim
who loves his triple
[1] I know there are some kludges you can do with certain double front levers to make them kind of triple compatible, but they're not the same as having a proper triple front lever.
- Xplora
Postby Xplora » Thu May 08, 2014 3:39 pm
- simonn
Postby simonn » Thu May 08, 2014 4:42 pm
However, for a roadie 50/34 11-28 is pretty much ideal for Sydney. FWIW, I have 50/34 12-25 on my roadie, only because I had a 12-25 cassette kicking around.
- nirismo
Postby nirismo » Sun May 11, 2014 4:03 pm
What would I need and how much to get a 50/34 and 11-28? Will be changing it on a TCR Advanced 2 (2014). It is easy for a dude like me who knows nothing about putting a bike together?
- open roader
Postby open roader » Sun May 11, 2014 4:38 pm
http://www.this link is broken.au/shimano-crank- ... owtech-ii/
Shimano 105 compact cranks will cost you $144
http://www.this link is broken.au/shimano-105-57 ... -chainset/
A Shimano 105 11-28 cassette will cost you $36 if you can wait for it come back into stock or an Ultegra 11-28 will set you back $51
http://www.this link is broken.au/shimano-ultegr ... -cassette/
This is simple swap out > swap in stuff assuming you have a chain whip and a cassette ring wrench........
http://www.this link is broken.au/bbb-btl-11-tur ... whip-tool/
http://www.this link is broken.au/bbb-btl-12-loc ... oval-tool/
If you don't want to buy the tools then the whole job will take a shop mechanic under an hour to complete so ask about for hourly rates / charges if you are not keen to do it yourself.
- herzog
Postby herzog » Sun May 11, 2014 4:43 pm
- singlespeedscott
Postby singlespeedscott » Sun May 11, 2014 5:02 pm
A 39x32 is the same as a 28x34 but you have the top end of a race bike with a 53x12, not that most people need a high gear like that.
- Xplora
Postby Xplora » Sun May 11, 2014 5:06 pm
If you are lucky, you'll cut it the right length ...herzog wrote:You'd also need to shorten the chain a touch.
Same chain for me on
50/34 - 11/28
50/36 - 11/28
50/36 - 11/23
53/39 - 11/23
- open roader
Postby open roader » Sun May 11, 2014 5:14 pm
I'd do the swap over first, then ride to see if adjustment is required.
