I'm used to an ETT 57.4cm which is Trek Madone H2 = relaxed road bike geometry for a 58cm frame.mitchy_ wrote:what ETT and head tube length are you after? that might help us to help you.
my TCX for the same size ETT has a shorter head tube than the CAADX, so i'd suggest you look at more CX bikes!
I have the stem slammed most of the time, but if I was doing a lot of hills and >130k, I'd raise it 1cm.
I've adapted to a 130mm stem from stock 110mm over a few years and losing 15-20kg.
I prefer to use stack height rather than head tube length, the former being 59.8cm on my Trek. As indicated above, I could go to 61cm for enduro rides
The head tube is 19cm for interest.
So for a gravel bike, I'd like to stay around the 57.5cm ETT. I can always use a shorter stock stem.
I've had some criticism for not 'getting' what adventure/gravel riding is and wanting this ETT.
However, as I've said above, in the real world, I won't be doing 100% gravel/adventure. In all likelihood, I'll be doing mostly tarmac and 5-10% off trails/gravel.
I also like to cruise around 35kph, and regularly do 35-40 for fitness.
And as I alluded above, I've get a lot more low back pain when sitting up high and riding slower.
I've ridden over 10,000km pa for the last 10 years, so have a good understanding of what is best for my body today, but more importantly, I am aware of how my mind and body will age over the coming 10 years....which is why I want a durable all purpose bike rather than a pure roadie.
