Doh...LOL...yeah they are some pretty measurements he has there!...especially top tube length if I am reading it right.twizzle wrote:Lol - that was for Kennyrocks, not you. The competivecyclist fit calc inputs and reports in cm's, but takes number in fractions anyway.toolonglegs wrote:I will dig out my steve hogg info and get it right!...give me sec.twizzle wrote:I reckon you had a data entry issue. For a start, you should be using cm, not mm.
201 cm human frame = ?? cm bike frame?
- toolonglegs
Postby toolonglegs » Sat Sep 13, 2008 4:54 pm
- toolonglegs
Postby toolonglegs » Sat Sep 13, 2008 4:58 pm
I bear 8kg more on my left leg standing at rest!.1 kg is considered excessive!.
- twizzle
Postby twizzle » Sat Sep 13, 2008 5:52 pm
My 'L' on your sheet is (measured from the bike) 1050 with a 175mm crank length. And I didn't measure to the pedal spindle, I measured to the top of the pedal, so that probably makes it ~1060.
Postby Zujan » Sat Sep 13, 2008 6:45 pm
twizzle,your L=1060 how do you stop at the traffic lights????
Im confused,let me messure my L again..............
2010 Cervelo R3/SRAM Red, 3T Team,Fulcrum Racing 1
Postby Zujan » Sat Sep 13, 2008 7:16 pm
L=1035mm to C/L of pedal spindle to the top of seat
L= 1020mm to top of the pedal
J=635mm
M=630mm
A=590mm
Postby kennyrocks » Sat Sep 13, 2008 7:18 pm
Thanks for heading me in the right direction
Postby Zujan » Sat Sep 13, 2008 7:20 pm
hey,this is wrong,you mean add another 2.5mm.........so I reckon it is 1009 or when on Cannondale 1011.5mm?????twizzle wrote:
Sorry got it wrong...1.09 meters...1090mm or add another 25mm on when I am on my cannondale with 180mm cranks.
I am all legs...hence the screen name.
- toolonglegs
Postby toolonglegs » Sat Sep 13, 2008 7:21 pm
Yeah ignore what I said before...i have a memory like a ...?Zujan wrote:Toolonglegs,your L=1006,how did you end up with 1090 this is 84mm over????
But yeah 1006 with 180mm cranks or 1008-9 with 175 cranks.
Twizzle how tall are you....your legs are 5 cm longer than mine...
Postby Zujan » Sat Sep 13, 2008 7:23 pm
hehe my kids 'Wii Sport' saying that Im perfectly balanced,even my kids at 8 and 11 are slightly out of balance...toolonglegs wrote:I bear 8kg more on my left leg standing at rest!.1 kg is considered excessive!.
but question is;can you trust a Wii?
- toolonglegs
Postby toolonglegs » Sat Sep 13, 2008 7:24 pm
maths..whats that?....Zujan wrote:hey,this is wrong,you mean add another 2.5mm.........so I reckon it is 1009 or when on Cannondale 1011.5mm?????twizzle wrote:
1006mm when on 180mm cranks....as i was fitted.
Plus 2.5mm on the Ribble with 175mm cranks.
- toolonglegs
Postby toolonglegs » Sat Sep 13, 2008 7:25 pm
yeah 8kgs is a bit much...will recheck it one day...was 3 years ago.Zujan wrote:hehe my kids 'Vii Sport' saying that Im perfectly balanced,even my kids at 8 and 11 are slightly out of balance...toolonglegs wrote:I bear 8kg more on my left leg standing at rest!.1 kg is considered excessive!.
Postby Zujan » Sat Sep 13, 2008 7:31 pm
I can not belive that he is on 1060........my God,those are very long legs then.....I mean Im 195.5 cm tall and my LBS saying that they have fitted only one men with legs longer then mine;his name is Glenn McGrath......but 1060,woooops....="toolonglegsTwizzle how tall are you....your legs are 5 cm longer than mine...
Postby kennyrocks » Sat Sep 13, 2008 7:58 pm
Haha another opening bowler here, the look on the bike store bloke's face when I walk in almost makes up for the fact that theres almost nothing in my size.Zujan wrote:I can not belive that he is on 1060........my God,those are very long legs then.....I mean Im 195.5 cm tall and my LBS saying that they have fitted only one men with legs longer then mine;his name is Glenn McGrath......but 1060,woooops....="toolonglegsTwizzle how tall are you....your legs are 5 cm longer than mine...
Here are my corrected results:
The Competitive Fit The Eddy Fit The French Fit
Seat tube range c-c 60.9 - 61.4 62.1 - 62.6 63.8 - 64.3
Seat tube range c-t 62.8 - 63.3 64.0 - 64.5 65.7 - 66.2
Top tube length 59.0 - 59.4 59.0 - 59.4 60.2 - 60.6
Stem Length 12.2 - 12.8 11.1 - 11.7 11.3 - 11.9
BB-Saddle Position 93.5 - 95.5 92.7 - 94.7 91.0 - 93.0
Saddle-Handlebar 57.9 - 58.5 58.7 - 59.3 60.4 - 61.0
Saddle Setback 5.4 - 5.8 6.6 - 7.0 6.1 - 6.5
EDIT: This means an Allez in 61 cm frame would fit me referring to the geometry. Hooray! lol
- twizzle
Postby twizzle » Sat Sep 13, 2008 9:04 pm
I rechecked, it's 106cm from pedal spindle to the top of seat in line with the seat tube.
Now - I'm not saying it's the height it *should* be. I can still drop my heels when pedalling, it's smooth at cadence, and I don't think my hips are rocking - but they could be. Certainly, no-one has said anything to me when I'm riding, and me knees are still bent at the bottom of the stroke. And if I drop the saddle by a couple of cm's, my knees start locking up when pedalling... the result of knee injuries in the past. It's the height which 'works for me' as it were.
I'll be doing some more 'me' measurements tonight. Results tomorrow... when I have time. Wife and daughter are away in Syd tomorrow, so it's me and the three boys for the day.
- twizzle
Postby twizzle » Sat Sep 13, 2008 10:00 pm
Inseam - 95.2.
My height (just measured) 190.3. I'm pissed off - I used to be ~ 2 - 3cm taller!
After plugging all my numbers (taken as best I could by myself) in to the fit calculator, it gives a BB spindle to seat height max of 88.4, plus my crank arm of 17.5cm gives me 105.9 as the absolute max calculated height for 'L'. And you will love this - there it was, sitting on the bike fit from the physio last year - predicted seat height of 105.9. Mind you, they didn't say how this measurement was to be checked... but my seat height from the ground is 113cm, so there is no way in hell it was for measuring that.
TLL - I'll be having your user name, thank you very much. 'Too long legs' indeed. You shall hereafter be known as 'Almost Too Long Legs'.
- twizzle
- twizzle
Postby twizzle » Sat Sep 13, 2008 11:24 pm
The usual - slow down, forget to unclip, fall overZujan wrote: twizzle,your L=1060 how do you stop at the traffic lights????
Seriously : unclip and stand on right foot. Obviously, not while in the saddle. I'm on a hybrid so the BB is quite high up to start with.
- toolonglegs
Postby toolonglegs » Sat Sep 13, 2008 11:48 pm
- twizzle
Postby twizzle » Sun Sep 14, 2008 7:16 am
So ATLL, what's you inseam?toolonglegs wrote:Pretty impressive leg lengths....I want to see a photo of the long legged crab man a bike .Interesting when I had a bike fit with Steve Hogg he said that out of all the people he has fitted...say from 140cm to 200cm,the actual body/torso length is always within 8cm...so the variations are all in the limbs!.
And boring story (just to prove I'm a 'sensitive male'), a couple of weeks ago after starting to increase the K's after sickness I started getting pain around the ITB's near the hip joint, so I dropped the seat by 2mm and it went away. Now, where is that pea in my bed...
- Kalgrm
Postby Kalgrm » Sun Sep 14, 2008 6:11 pm
TLL,toolonglegs wrote:maths..whats that?....Zujan wrote:hey,this is wrong,you mean add another 2.5mm.........so I reckon it is 1009 or when on Cannondale 1011.5mm?????twizzle wrote:
Can you explain to me why you're only raising your seat height 2.5mm when the crank is 5mm shorter please? I would have assumed you would need to raise it the full 5mm to keep the same knee extension when the pedal is down.
Graeme
- toolonglegs
Postby toolonglegs » Sun Sep 14, 2008 10:03 pm
Maths!...yes 5mm is right...sorry,gosh I must be tired!!!.Kalgrm wrote:TLL,toolonglegs wrote:maths..whats that?....Zujan wrote: hey,this is wrong,you mean add another 2.5mm.........so I reckon it is 1009 or when on Cannondale 1011.5mm?????
Graeme
